83 berlientta questions
Old Mar 11, 2003 | 12:24 AM
KsKid's Avatar
i own an 83 berlinetta, the year without the digital dash, crazy stereo... all of that stuff. so i was wondering. whats so different about my car than from the Iroc and z 28? the only thing i see is it doesnt have the ground effects. thanks for any info you know of...
Michael
Old Mar 11, 2003 | 12:29 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
The Z28 is the higher performance/top model. Check out the Tech Data www.thirdgen.org/tech/techdb.shtml also.
Old Mar 11, 2003 | 08:40 AM
KsKid's Avatar
thanks, i knew about that a wile back but didnt know what stuff meant untill now. anyway is there anything else not found in tech articles that anyone can tell me?
Old Mar 11, 2003 | 11:56 AM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Um yea well, you car's suspension isn't as high end as the Z/28 in '83 and the IROC's you couldn't even get one until '85 so that would explain some of the differences. Many other little things aswell like the rim selection is only 14's if I remember correctly, for sure no 15" 5 spokes on Berlinetta's. Also the main reason I don't like the Berlinetta's the most powerful engine available was the all mighty LG4, no LU5 or L69 engine available in the Berlinetta's in '83 .
Hope this helped a little, Later, Garrett
Old Mar 11, 2003 | 01:57 PM
KsKid's Avatar
well yeah the rims... they suck, 14" 15 spoke colored crap... but hopefuly soon i'll be replacing those crappy things. thanks for the info
Old Mar 11, 2003 | 02:27 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
I thaught the berlinetta was the high performance flagship for chevy(next to the vette).The berlinettas have more insulation and sound deading(this is debatible cause the custom interior on the z/28 is probly the same).The berlinetta didnt have the rear sway bar available( because old people dont take corners fast).I think the camaro berlinetta is a sleeper,yes with the optional white stripe tires especialy.I would compare the berlinettas performance to the newer 91-92 firehawk.Ever heard of a 1le berlinetta? yes thats right the berlinetta is the unsung hero.
Old Mar 11, 2003 | 03:41 PM
Car: 1991 Formula
Sure the Berlinetta can be a sleeper, you just need to do an engine swap, and tranny swap, and rear end swap, etc. Oh wait a minute if that the case anything can be a sleeper. Even a Vega or a Monza!! I know I surprise alot of people with my V-8 Monza even if I have to remove the motor mount to change the spark plugs !! What was GM thinking
Later, Garrett
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
