Different types of REAR LOUVERS?
Old Jul 24, 2003 | 07:44 AM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
I know w/ w/ o rear brake light...
nut metal, plastic, one and three pice?
whats the diff? and are there more?
have pics?
(please no bs about rear louvers)
Old Jul 25, 2003 | 10:02 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The difference is in the manufacturer. GM used metal slats with ABS side pieces to give them the one piece look. As you mentioned, the 3rd brake light piece was plastic with shorter metal slats for 91 and 92 and I believe it was just plastic in 86 (around the 3rd light). There are 3 piece louvers available from aftermarket companies that look like 3 pieces and look hideous in my opinion. Some are made of strictly plastic and look cheap and rattle. The aftermarket louvers are not made to the quality standards that GM put into theirs. I have an original GM set that uses rubber tubing to rest on the window and absorb sound. I have seen aftermarket sets that use a foam tape. The foam breaks down over a few months and the louvers rest on the window and rattle.
GM uses clips that surround the glass frame at the top and sides and the louvers attach to the clips. I have seen some aftermarket sets that require the 4 glass bolts be removed in order to install a metal strip that the louvers attach to. This can cause rattles to if the window is overtightened. The glass can also shatter if the bolts are overtightened.
I don't know what else to tell you. I like the GM set.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
