Underdash plastics
Old Aug 7, 2004 | 08:32 PM
  #51
MNformula350's Avatar
87 Iroc-z 305 TPI, 5 Speed G92 Bose stereo = I have the panels. am i the original owner no, was the previous owner the original owner no.
Old Aug 8, 2004 | 12:42 PM
  #52
Drew's Avatar
My 87 Iroc didn't have the hush panels when we got it, so I added them. It didn't have any floor lights at all though, and its not a bose car. When I added them I didn't have to drill any holes or anything like that. I'm fairly certain the car had the panels from the factory, and that a previous owner/mechanic removed them cause he was an idiot.
Also, every thirdgen I've ever owned has had the diagnostic connector cover. Along with just about every GM car I've ever owned.
Another side note is that there are MANY different hush panels used on thirdgens between 82-92 and most of them aren't interchangeable. For example, a drivers side panel from an 82 Z28 fit my 83 Coupe fine, but wouldn't come close to fitting in my 87 Iroc, but the drivers side panel out of an 86 Firebird fit the Iroc like a glove. Also, the fuse block covers are different from some years to others.
Old Aug 8, 2004 | 01:46 PM
  #53
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
Do you have the under dash lights then? When I had the hush panels and the bose kick panels the light on the pass. side would rub against the panl and mlt the carpet.
Old Aug 17, 2004 | 08:27 PM
  #54
89_IROC_98U's Avatar
I know that most people are speaking of '87 cars, but my '89 IROC-Z has the "form-fitted, black plastic cap" with 'DIAGNOSTIC CONNECTOR' printed on it that Willie spoke of. My car is a 350 car. Is there any word yet on how to tell whether or not these cars were supposed to come with the plastics? My car has them but I'm restoring it, so I don't want to lose points for having something that isn't supposed to be there.
- 89_IROC
Old Aug 17, 2004 | 09:52 PM
  #55
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
my 89 RS, 5.0 manual had them
my 89 IROC 5.7 auto did not
both had ac/heater
Old Aug 18, 2004 | 01:41 AM
  #56
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
All five of my 3rdgen Camaros had 'hush panels'. None of them were Bose or 350 equiped. I was not the original owner of any of them. No help here...
Old Aug 18, 2004 | 07:27 AM
  #57
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
- 89_IROC
You won't lose points for having them. I lost points for not having them. Most cars do have them but some don't, from the factory! My wasn't supposed to have them for whatever reason, but since most cars have them, the judges figured I was missing interior components.
Old Aug 18, 2004 | 01:30 PM
  #58
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
My car also came without them from the factory. Its the L98, IrocZ, No Bose, Non A/C, pretty much un optioned car. I mentioned the non a/c thing because with the non a/c you have the underdash vents which they made different covers for. It took me a while but I was able to find covers that fit and had the openings for the vents.
Old Aug 19, 2004 | 01:53 PM
  #59
TA76's Avatar
I was on the team that judged you car Scott. The "third-gen" expert on our team said they were missing, I initially did not subtract any points until he pointed out the panel issue. I had an 87 IROC w/350, Bose and leather and I don't think it had panels either. However, mine went thru a number of owners before I had it. Regardless, it was the nicest 3rd gen there.
I wonder if the panels could have been out of stock for a short period of time and the factory just skipped putting them in. Was the Ohio plant still producing f-bods in 87? Just a thought...
Old Aug 19, 2004 | 06:42 PM
  #60
I guess I'll play it safe and replace the panels, although I'd still like a definitive answer either way (if one exists). Maybe it's better to let sleeping dogs lie - proving that a judge is mistaken may not be in my best interest
- 89_IROC
Old Aug 19, 2004 | 07:43 PM
  #61
CaysE's Avatar
The only way we're really going to find an answer on this is with RPOs. Unless you can find someone that was on the thirdgen design team.
Old Aug 19, 2004 | 07:52 PM
  #62
RSFreak's Avatar
You'd think the judges would need to have a more thorough knowledge of 3rdgen options.
  #63
Are RPO descriptions this detailed?
- 89_IROC
Old Aug 19, 2004 | 08:42 PM
  #64
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are two RPO codes that I have found, as to whether they pertain to the underdash panels I can't say for sure. In earlier models, there was a BS1 code for acoustical insulation (also known as Quiet group option). In later years there was another RPO code, it was B3E and was for the Noise group option. Have not yet seen anything specifically pertaining to underdash (knee bolster) panels in either the camaros or firebirds.
Old Aug 19, 2004 | 08:44 PM
  #65
I'm starting to suspect that you were on the 3rd gen design team *eyes Trickster suspiciously*
- 89_IROC
Old Aug 19, 2004 | 09:24 PM
  #66
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
- 89_IROC
Now what would put such a suspicious thought like that in your head?
Old Aug 19, 2004 | 09:28 PM
  #67
Well, it certainly wouldn't be your overwhelmingly vast knowledge of (nearly) everything 3rd gen
I never cease to be amazed at the endless amount of knowledge on these boards - everything from the blatantly obvious to the most miniscule and little-known facets of these cars. You guys rock
- 89_IROC
Old Aug 20, 2004 | 05:38 AM
  #68
scottmoyer's Avatar
Well, I'd say that this forum is probably the place to find the most knowledgable answers, however, we still haven't answered this one. The judges can't know everything. I met the "expert" that took the points off. He has a white LS1 thirdgen convertible. It's been seen on these boards and we support his company for 3rd gen parts. Again, if most cars have these, then it would be obvious that a car without them is "missing" them. That's why I originally posted this thread. I need to know!
Old Aug 20, 2004 | 12:31 PM
  #69
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I actually found the 87 IROC-Z I've been looking for all these years, 4 1/2 to be exact! (Whoo Hooo, and thanks to SM and 87 B4Z TPI 5Spd for helping make it possible!) I will have it soon, but I already know that it has no hush panels. It's a Van Nuys L98 1SC (without D42) car. Basically it has every option except BOSE, cargo cover, hatch locking storage cover, and leather seats. It's an incredibly documented and near mint 67,000 mile original except for PROM chip and stereo/amp/speakers. So here's another untouched car without them.
There has to be an RPO or reason for it because any model could have them or not have them.
Old Aug 22, 2004 | 06:57 PM
  #70
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
For those who don't have the lamp group option, check the under dash harness right where the hush panels screw in. I think you will find the sockets for the courtesy lamps taped up there. Thats where I found them on my car. All I had to do was add the bulbs (194) and snap them into the hush panels!
Old Aug 23, 2004 | 06:34 PM
  #71
CaysE's Avatar
My 86 has the BS1 code with underdash panels. My 92 RS has the panels without BS1 or B3E. It's possible they were added into the 92 though.
Old Jul 26, 2006 | 04:57 PM
  #72
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Time to dust this off, can you identify the years these came from?
Pics will be posted in a few.
Old Jul 26, 2006 | 05:30 PM
  #73
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Here are the pics.
[IMG][/IMG]
[IMG][/IMG]
Old Jul 26, 2006 | 11:32 PM
  #74
David M's Avatar
Car: '84 Z28
Engine: L69
Hush panels
Well I thought it would be a combination of TR9 (aux lighting) and BS1 (quiet sound group). But BS1 wasn't available in '87. Anyway my '84 Z28 has the hush panels on both sides. The car has TR9, YE2 (radio), 60C (custom cloth interior). Just for the record.
Old Jul 26, 2006 | 11:48 PM
  #75
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
I've got an 87 Iroc with a 350 L98. Has the bose, no hush panels, no lights, no brackets. ALDL connector on the right in the pic. Carpeted center console. It did, however, have the u-clips under the dash for the panels to be installed. I found a passenger panel and bolted it right up. Looks great. no spot for a courtesy light though. That's ok, because like I said, I don't have any.
Originally Posted by 82 Iron Duke
Here are the pics.
[IMG][/IMG]
[IMG][/IMG]
Is the one on the bottom from a bird?
Last edited by 87IROCZ350TPI; Jul 26, 2006 at 11:51 PM. Reason: Automerged Doublepost
Old Jul 28, 2006 | 08:46 AM
  #76
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
my 87' sport coupe is a non-bose car with the interior lighting package, never had the hush pannels. and i've known the car since new.
Old Jul 31, 2006 | 03:19 PM
  #77
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
So far it seems that we've never been able to make a solid determination as to specifically what cars get them and what don't.
I didn't go back and re-check every post, but from those that I did check out, it seems that all of the cars without the hush panels were Van Nuys cars. I know there are other differences between Van Nuys and Norwood cars, and perhaps this is another.
We've ruled out that it's a 350 issue, and we've ruled out that it's a Bose issue.
We haven't ruled out specific RPO codes, interior packages, or assembly plant.
This is extremely interesting for a thirdgen geek like me.
Old Aug 3, 2006 | 09:18 AM
  #78
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
My 1990 350 Iroc with the Bose system did not come with them from the factory. The reason being with the Bose you can't open the fuse cover.
Old Aug 8, 2006 | 10:56 PM
  #79
Hotdogstand's Avatar
Originally Posted by Willie
Scott,
I know without a shadow of a doubt that 1987 and 1988 IROC-Z's with the 350 did not come originally with the hush panels. I do not know the reasoning. Weird.
Like your car has, the courtesy light bulbs are mounted on plastic "L" brackets on these cars only.
Willie
My guess is to amplify the great sound of the 350.
Old Sep 21, 2006 | 12:47 PM
  #80
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
My '92 Z came with Hush panels (I believe the floor lighting wasn't available for the '91-'92 years though). I also had the Delco Bose System with the kick panel speakers as well.....
Old Sep 26, 2006 | 02:54 PM
  #81
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
My 89 Iroc doesn't have them but it does have the lamps, and form fitting diagnostic cover I always thought the previous owner removed them, but know Im thinking it never came with them, and I think ill keep it that way
Old Sep 26, 2006 | 06:07 PM
  #82
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My 85 IROC, which was originally an LG4 and highly optioned (though it was equipped with an AM radio), had the hush panels. Norwood car.
JamesC
Old Sep 26, 2006 | 06:24 PM
  #83
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
My '88 sport coupe didn't have the hush panels when I bought it. I'm not the original owner, though. It has the L brackets for the lights and the little cap for the diagnostic connector so I'm pretty sure it never had them.
Old Jan 7, 2007 | 12:44 PM
  #84
shades69x's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Hi all,
I am impressed that this thread was started in 2004 and had alot of interest. I have a 91 RS Vert with the hush panels but no lights, but the pocket the lights are supposed to be in are there. I have all of my rpo codes but really don't know which ones this might be connected with (B18?). It seems the interest has waned on this topic.....
Old Jan 7, 2007 | 11:05 PM
  #85
shades69x's Avatar
Engine: 305 TBI
In addition My RS was made in Van Nuys, maybe it is connnected to rpo IP2?? Was there a resolution on this?
Old Jan 25, 2007 | 06:06 PM
  #86
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
I don't ahve a good answer for why or why not the hush panels were in some cars and not others, or for what year(s) they may have been included or excluded. I also do not know of any RPO time code that explicitly called for them to be installed on a car.
I am the original owner of of 1982 Z28 with the Cross Fire TBI. I have hush panels on both the driver's and passenger's sides. I did not have the BS1 option. I do have the TR9 " Auxiliary Lighiting" and 79C "Custom Cloth Bucket Interior" I also have the YE4 Raido option, which is the stero radio with the cassette player. Speakers on this car are under the dash, not down by the driver's feet. The car was built in the Van Nuys plant.
Here are the pics.
[IMG][/IMG]
[IMG][/IMG]
82 Iron Duke....
The top photo looks like my driver's side hush panel from the 1982 Z28. I have no idea how many model years this panel was used for. But what is the RPO for the mold, etc.
Take a look at these photos of the panel and the fuse cover....
Dave
Attached Thumbnails Underdash plastics-camaro-021-medium-.jpg   Underdash plastics-camaro-013-medium-.jpg
Old Jan 25, 2007 | 08:05 PM
  #87
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
My 85 bought new by me(only owner) has both hush panels. Car was ordered radio delete because I installed a aftermarket stereo system. Badman
Old Jan 25, 2007 | 10:00 PM
  #88
online170's Avatar
Car: 1987 Firebird
Engine: 355
Just wanna thank willie. I saw one of those little rectangular peices floating around in my 87 firebird that i recently purchased, and for the life of me i couldnt figure out what it was off of, or where it came from!!! But all is well now.
Old Jan 25, 2007 | 10:58 PM
  #89
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
My '83 Z28 is a Van Nuys car with Custom Cloth Interior,which included RPO-BS1 quiet sound group,RPO-TR9 lamp group and RPO-B48 luggage compartment locking storage/deluxe trim(although this most likely has nothing to do with the hush panels).She has the hush panels on both sides with the kick panel lights installed in them and the snap on ALDL cover.The sound group is the most likely candidate,to me,for the panels being there.And the interference with the BOSE kick panels for them not being there.Maybe the Bose equipped cars had additional sound deadening against the firewall.This sounds like another GM using when it's available not worrying when they weren't.
Old Jan 27, 2007 | 04:30 AM
  #90
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Axle/Gears: 3.27 BW
My 350 87 didn't have hush panels either. I didn't like the wiring hanging down from the pass side, so I went and got a set out of an 88 AC car at the junkyard. Well, two 88 AC cars. One's heater core exploded during a fire, so the pass panel was unusable. I had the little brackets, but removed them to put the lights in the hush panels.
Old Jan 27, 2007 | 09:27 PM
  #91
boussole's Avatar
Car: 91 ws6
Engine: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
Transmission: TRANSMISSION, MAN 5 SPD, B0RG WARNE
Axle/Gears: AXLE REAR, 3.42 RATIO
no ALDL COVER - 14083923 panel in my ws6
Old Jan 27, 2007 | 09:28 PM
  #92
boussole's Avatar
Car: 91 ws6
Old Jan 31, 2007 | 03:13 PM
  #93
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
OK. I have a 87 IROC fully loaded. 350, leather, bose.... The only thing it dose not have is a power antena and rear defroster(I think it was deleted because of the louvers). But it did not come with the hush panels. I don't think they would fit with the bose kicks there. I have the little meatel light socket things.Next time I am working on the 89. I'll take the hush panels off and see if they fit on the 87. Adam :-)
Old Jan 31, 2007 | 03:19 PM
  #94
Axle/Gears: 3.27 BW
You have a rear wiper with louvers? I have the defroster with mine, but no wiper.
Old Feb 3, 2007 | 09:16 PM
  #95
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I have an 88 Camaro Sport Coupe. I did not have the panels or the courtesy lights. However, I inspected under the dash to find a white wire and orange wire going to a bulb holder. I put in a bulb and noticed it lit up when I opened the doors. This courtesy light wiring was installed just hidden with a mash of wires under the dash. I bought the hush panels on e-bay and now I am set. Seems to me your car probably came that way from the factory and did not have the option. Some people have upholstered center consoles and rear hatch areas as well. These were all options.
Old May 6, 2007 | 02:28 PM
  #96
blkiroc87's Avatar
Car: 1987 IROC convertible
Engine: 305 t.p.i
Transmission: 5 speed manual
Axle/Gears: Borg-warner 3:45
Re: Underdash plastics
I have the same question that you do. I just picked up a 1988 iroc 350 with 2200 miles form the original owner the car has the Bose sound system also. As I was going through the car I noticed that these panels were not there. I also have the coutesy lights that are mounted to a bracket and mounted to the side kick plate. I called the owner that I got the car from today. He told me he never messed with the car and no one else ever messed with the car. He said they never were there. I also have a 1987 iroc convert with 12,000 miles. This car does have them but the coutesy lights turn and snap into the sockets in these under dash panels. I'm really starting to think that some cars had them and some did not. I think the coutesy lamp mounts would be the clue if the car came with them or without them. Thanks Al
Old May 6, 2007 | 04:56 PM
  #97
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
If it matters- I have an 88 T/A L03 with both panels. It has the Performance Stereo Bose, but the speakers aren't in the kicks.
Old May 30, 2007 | 01:44 AM
  #98
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
well I have no hush panels in my '85 Z28 with the LB9/700r4.
Heres a picture of my RPO codes:
It always felt as if there was supposed to be a cover there. You can see all the wires and the light bulb hanging down, etc. If there is a hush panel available for my car I would love to have one.
Old Jun 4, 2007 | 04:53 PM
  #99
Tonyrodz's Avatar
Transmission: auto
I had an 85 Z back in 87--was fully loaded inside but no pwr mirrors, LG4 car. I had the hush panels in it. bought it from the dealer--I was the 2nd owner. Original owner was a mechanic at the same dealer so I'm pretty sure car was unmolested--plu it was only 2 yrs old. I also had an 85 base Camaro w/the 4 cyl. Only options were rear defrost, auto and a/c. Car definitely didn't have the hush panels--had the metal brackets for the interior lights. also had a cap that slide onto the diagnostic port. The Z had a cap on the hush panel for the port.
Old Sep 19, 2008 | 11:58 AM
  #100
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
My buddy has a fairly stripped down 88 sport coupe
-v6
manual windows, trunk, locks
-t-tops
-no lamp group (hood and hatch light)
and his car did not have the hush panels, but he is also not the orig. owner
my 85Z does have them and its an alright optioned car.
-power windows
-305
-lamp group
-cruise
-delay wipers
-defroster
-stock tape with eq
my car is a van nuys car.
