help: need to find out what a part number came one (strut and rotor)
Old Sep 18, 2004 | 12:31 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Does anyone have access to GM part numbers? I have a 1LE brake setup that the numbers don't match.
1LE brake rotors are suppose to be 18060230
My brake rotors are 18016211.
Are these the new casting numbers, or perhaps the last ones they made? They are indeed 12". I called my local GM and they don't have this number.
My front struts are 22074399 with a second number below that of 33694311.
1LE struts are suppose to be: 22064153
My struts have a "LB" code (sticker) on them which is correct for a 1LE car (got this from a 1989 1LE build sheet).
In both cases, my numbers are numerically larger which typically means a later or updated part.
Any help would be appreciated.
Researchly,
Mark.
1992 Trans Am
May 10, 2023 07:19 PM
Steve78LT
Feb 24, 2016 12:15 AM
twest2k2
Aug 24, 2015 11:26 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
armybyrd
Aug 10, 2015 09:23 PM
