Fender rails/ core support
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
does anyone know where i can find some replacement parts for my 91 RS Convt. I'm looking to replace both front fender rails and the core support, the car had been in an accident in the past and i would like to fix what i can still see is not right. and what about the inner fender wells, the actual metal to where the struts mount to.
is there a compant who makes replacment parts? or am i stuck buying a doner car? if thats the case, does anyone know of any in NE ohio for cheap?
thanks
thanks
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
I do not think those parts are made for replacement anymore, by either GM or aftermarket. At one time you could buy the core support from GM, but it came in individual pieces that had to be welded together.
Your best bet will probably be finding a good donor car without a damaged front.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
