headlight
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
yes and no.
Yes it will fit but you have to remove the bezel from around the light in order for it to work without binding.
Basically all of the moving parts are different, except the motor & gears. The headlights on the 91-92's are also smaller in size, so the 91-92 bezel will not work either.
The only part that I remember being interchangable was the bracket that bolts to the car, the motor assembly and the arm.
Sorry.
JOhn
Sorry.
JOhn
