Seatbelt/Warning buzzer modual question
Old Aug 28, 2005 | 09:50 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Just wondering if the seatbelt warning buzzer is the same for all years or did they change? Need to know if a later model will fit an '82. I think the later ones are taller than the '82-'84? moduals and might have a different "pin" configuration but I don't have one to compare. Also does anyone know the part number(s)?
Old Aug 28, 2005 | 10:26 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
we have a seat belt buzzer?
Old Aug 28, 2005 | 10:58 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
I would think they would be the same for the most part. I know the early ones were typically blue in color.
Make sure you get one from a Firebird rather than a Camaro. Firebirds had a chime(like a Buick, Olds, Caddy) and the Camaro had an annoying buzzer like the 2nd-gen F-bodies.
The "tone generator" modules are faily easy to fix. The seat belt chime is controlled by a disc(a timer) that is soldered on the board. The disc heats up and eventually the seat belt chime stops working. I resoldered mine with higher temp solder and its been fine for a few years so far ...
Old Aug 28, 2005 | 11:33 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
i never knew their was a seat belt buzzer in these cars where exactly is it located at? and i bet it would explain why my seatbelt light doesnt come on other then having a bad bulb, which in that case i cant figure out how to get it out...
Old Aug 30, 2005 | 04:46 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
thanks for the info. Also didn't know about the differences between the Camaro and Firebird tone...I just figured the Firebird would "buzz" like all other early 80's cars.
Old Aug 31, 2005 | 12:51 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I took mine out day 1 .. *** i hate those freaking things
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
