Please explain "F" Body
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
Sorry guys, I'm kinda ignorant to this. however my question is
I noticed the cars we love are F bodies, I noticed some otehrs are called H bodies. Does Ford make an F body?
Can someone explain how and why the term F body came into play.
Thanks in advance for your patience!
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Different cars have a different designation. A B C ..so on.
The 4rth digit of the vin in your car should be an F.
I'm sure someone else could explain it better.
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
F just happened to be the letter GM chose for the Camaro/Firebird chassis when it was first being developed around 1964.
Chevelle/GTO/Gutless/Skylark were A-bodies in the begining but then put on a G-body in the late 70's.
Impala/Bonneville were B-bodies.
Corvette is a Y-body
Notforsale: Whoever told you that it came from a "F" in the VIN number is pretty clueless.
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
I have 2 F Bodys, 1 J Body, and 2 W Bodies.
It a way to describe a platform of car that includes more than 1 division (Pont Chevy) and from the same corporation (GM)
The driveline components are for the most part interchanagble.
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Originally posted by Firebreed
I dont got an "f" on my vin, ANY where. so i dont think thats true...
I think its 84 or 85 and up only. The F body name did not come from the vin but GM started using it in the vin.
Just looked at a bunch of 3rd and 4rth gen vin's and all have F's
as the 4rth digit.
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Originally posted by Apeiron
The fourth digit isn't an F until 1987.
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Yah, Fbody, just the type of chassis.. 67-02 camaro and firebirds are all Fbodies, even tho their design has changed some over the years...
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Heres a quote from Scott Settlemire from GM
Each car line at GM was assigned a letter....for instance, the Chevelle--other GM intermediates in the 60s/70s/were the A body....Caprice/Impala/Parisienne/Bonneville RWD were the B bodies.....DeVille/98/Electra were C bodies........etc. The Camaro/Firebird were Fbodies.
The letters still show in the VIN.......Impalas/Montes today are W bodies.....Corvettes are Y bodies......
Note the VIN number.
for 4th gen cars: 2G1FP.....2 means built in Canada....G means General Motors...1 means Chevy....2 is Pontiac.....F...Fbody!
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
1985 - 2002 the 4th digit indicates the (car line), also called "body type" this is "F" in our case. Before that it was an assumed designation that was not used. Much like the Mustang is referred to be built on the "Fox" Platform.
When they went to the 17 number VIN numbering system in 1981 the numbers were ment for insurance purposes, and the information was not as useful as they probably hoped. All of our 82-92 cars start the same way 1G. 1 = US and G = GM the third designation is 1 = Chevy, 2 = Pontiac, 3 = Olds 4 = Buick 6 = Cadillac etc. But the 4th didget from 81-84 was the restraint system (thus where the insurance company comes into play). A = Manual belts, B = Automatic belts and C = Automatic belts (inflatable restraint). The carline & series was grouped into ONE letter IE S = Firebird, P = Camaro SC or Z28, etc. The body type for the cars was 87 = 2 door coupe, the 8th thru the 17th didgets in the VIN did not change their designation however.
In 1985 the 4th didget changed. The 4th didget which was the restraint system became the "Car Line" or Body type, thus "F" was introduced.
In 1987 the 7th and 8th didgest changed to what they are currently using. Where they were using 2 didgets to determine the body type, IE coupe/Convertable etc, the 7th didget became the body type IE 1 = 2 door coupe/sedan, 2= 2 door hatchback, 3 = 2 door convertable, 4 = 2 door station wagon, 5 = 4 door sedan, 6 = 4 door hatch back, 7 and/or 8 = 4 door station wagon etc...
Although the "G" body was the Monte-Carlo/Regal of the 80's my 95 Riv is also a "G" body. The letters sometimes change, especially when they changed the configuration from RWD to FWD as in the case of the Regal/Monte/Cutlass/Grand Prix went from a "G" in 1987 to a "W" in 1988 to current.
I hope that muddied the waters for you.
John
John
Car: 1992 Formula Firebird
Transmission: 5speed
Axle/Gears: limited slip/3.42
I believe that it is called an F-body car because the early cars had a metal tag riveted to the firewall(?), saying Body by Fischer. This is from my book of Firebird ID numbers (1967 -1993)
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I think what he is saying is, it was mounted on the firewall so its
F (irewall) body. Get it. Body by fisher mounted on the F irewall.
F-Body, or Body by F isher.
But that wouldnt make sense??
Anyway, it was refered to the body line.
Camaros and Firebirds are F-bodies, Just what GM choose.
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Turn your car upside down, the shape of the frame should be shaped like the letter your car is designated to.
NOTE: This comment was merely provided as a joke and I am not repsonsible for any belief in its credibility
Re: Please explain "F" Body
Re: Re: Please explain "F" Body
Originally posted by Firebat
Ford does not to the best of my knowledge. I think they have something called the Fox Body though, which is what the mustang is? Um, i'm not a Ford guy...
There is no Guessing the F body is just a letter GM used for the body of the car.
I thought I heard that the Fox platform was used for something like 30 years
I know from 79-04 used the same platform, but apparently so did the Mustang II platform from the mid 70's used something similar.
I thought 11 years was a long time for our cars 82-92
John
I know from 79-04 used the same platform, but apparently so did the Mustang II platform from the mid 70's used something similar.I thought 11 years was a long time for our cars 82-92
John
John
John
I got this off of a ford Site
The Fairmont was the first of Ford's FOX platform cars, this platform carries on today in a much modified form under the skin of the Mustang. The Fox platform was used for many Ford cars, starting in '79 for the Mustang and later including the LTD, Thunderbird, Cougar, Capri, and Granada.
Ford Mustang: The redesigned 2005 Mustang coupe will go on sale this fall on the new D2C platform. It replaces the Fox platform, which dates to 1978. Ford began building the 2005 Mustang in September at the Ford-Mazda joint-venture plant in Flat Rock, Mich.
The coupe debuts first, followed by a convertible in early 2005. An SVT Cobra version is planned for the 2006 model year.
Hotrodboba400
Dec 10, 2019 07:07 PM
Kenwood
Sep 4, 2015 05:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
