Question
Old Sep 6, 2005 | 10:57 PM
android's Avatar
Car: 1989 Iroc
Engine: 5.7 350 TPI
Transmission: 700r-4
Question
What would a stock 1990 IROC be running?
Is the 1990 IROC special? (collectable)?
How much do you think someone should sell one of these with
50-70k original miles?
Thanks guys!
Old Sep 6, 2005 | 11:41 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
90's irocs are rarer, limited run
worth between 3 and 5 grand
Old Sep 7, 2005 | 12:01 AM
android's Avatar
Car: 1989 Iroc
Engine: 5.7 350 TPI
ok i think im going to buy one that has 60k original miles and the interior is amazing. It has a lot of appearance goodies plus a cold air conditioner. The only thing is that it has a 5 digit odometer. Can you guy give me some pics of how the 90 odometer should look like. Thanks !
Old Sep 7, 2005 | 11:49 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
That's correct, it should have 5 digits, making it difficult to tell if it has rolled over. Make sure to do a carfax first to verify mileage, then good luck with your purchase!
Old Sep 7, 2005 | 12:28 PM
android's Avatar
Car: 1989 Iroc
Engine: 5.7 350 TPI
Ok so the 1990 Irocs come with 5 digit and 6 digit odometer?
How do I know for sure its a 1990
Old Sep 7, 2005 | 12:57 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
vin# under the lower part of the windshield, drivers side.
1987 - 1992
1 G 1 F P 2 1 H X H L 1 0 0 0 0 1
| | | | | | | | | | | +---------+---> Production Sequence
| | | | | | | | | | +---------------> Assembly Plant
| | | | | | | | | | N = Norwood (1987 only)
| | | | | | | | | | L = Van Nuys
| | | | | | | | | +-----------------> Model Year
| | | | | | | | | H = 1987
| | | | | | | | | J = 1988
| | | | | | | | | K = 1989
| | | | | | | | | L = 1990
| | | | | | | | | M = 1991
| | | | | | | | | N = 1992
| | | | | | | | +-------------------> Check Digit
| | | | | | | +---------------------> Engine Code
| | | | | | | S = 173 ci V6 LB8 (1987-1989)
| | | | | | | T = 191 ci V6 LH0 (1990-1992)
| | | | | | | F = 305 ci V8 LB9 (1987-1992)
| | | | | | | H = 305 ci V8 LG4 (1987)
| | | | | | | E = 305 ci V8 L03 (1988-1992)
| | | | | | | 8 = 350 ci V8 B2L/L98 (1987-1992)
| | | | | | +-----------------------> Restraint System
| | | | | | 1 = Manual belts
| | | | | | 2 = Manual belts (built in safety)
| | | | | | 3 = Manual belts (driver inflatable)
| | | | | | 4 = Automatic belts
| | | | | +-------------------------> Body Type
| | | | | 2 = 2 door coupe (hatchback)
| | | | | 3 = 2 door convertible
| | | | +---------------------------> Carline Series
| | | | Chevrolet:
| | | | P = Camaro (all models)
| | | | Pontiac:
| | | | S = Firebird
| | | | W = Formula, Trans Am
| | | +-----------------------------> Carline Code
| | | F = F-Body
| | +-------------------------------> Make
| | 1 = Chevrolet
| | 2 = Pontiac
| +---------------------------------> Manufacturer
| G = General Motors
+-----------------------------------> Country
1 = USA
2 = Canada
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
