V.I.N. Check please.
Old Sep 26, 2005 | 11:04 AM
kikgas01's Avatar
Car: 82 Z28
Engine: 463 BBC,roller rockers blah blah
Transmission: Hughes 350 turbo and Hughes stall
Axle/Gears: 9 Inch rear,Moser axles,410 locker
Hi.Just trying to figure out if my Camaro is a Z-28 Thanks in advance!
1G1AP87H4CL171887
Thanks again!
Old Sep 26, 2005 | 11:43 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Made in: United States
Manufacturer: General Motors
Model Year: 1982
Make: Chevrolet
Carline Series: Sport Coupe, Z28
Engine Code: 305 CI V8 LG4
Restraint System: Manual Belts
Assembly Plant: Van Nuys
Production Sequence: 171887
Carline Code: 82-84 does not have a Carline Code.
Body Type: 2 Door Coupe
Check Digit is Valid
This says it could be either a sport coupe or Z28, only way to know is if you have the Z28 RPO code.
Old Sep 26, 2005 | 01:50 PM
kikgas01's Avatar
Car: 82 Z28
THANK YOU!!!!Where would I look for the code?Thanks again!
Old Nov 19, 2005 | 09:22 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
build sheet or you are screwed
no RPO sticker til 84 in cars
i have the same problme with you
x2
as i have two 82's
ones a vin H 305 trans am without disc rear but with the largest sway bars and power bulge hood
and now i have a Z28 with vin H 305 that is badged inside and out with z28,
but since they are 82's..... theres no sticker or buildsheet to prove either one is what they are
screwed really
i and many others with pre-84 cars know how it feels..
we sympathize,,
good luck
Old Nov 20, 2005 | 08:44 AM
Klortho's Avatar
Car: 1987 GTA
the Trans Am you actually do have an option to find out, http://www.phs-online.com for Pontiac Historical services they should be able to give you the info on the T/A
Old Nov 20, 2005 | 10:18 AM
kikgas01's Avatar
Car: 82 Z28
O well.Thanks guys.It says Iroc Z-28 on the dash but has no Z badges.It has the ground effects though.
Old Nov 20, 2005 | 10:33 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
think they could tell me it is a WS6 without the disc rear ?
it has the WS6 bars and such
but drum 2.73 rear, LG4, 200C,
the PMD cloth interior color matched to exterior, light blue/dark blue
thanks
good luck with your camaro, hope you end up finding out more on it somehow
skeltor
Feb 2, 2016 10:37 AM
Jonesyfxr
Sep 26, 2015 02:08 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Nick McCardle
Sep 10, 2015 08:36 PM
