what is wrong with these gauges?
Old Nov 20, 2005 | 09:14 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Saw this on ebay. Seller says "Rare" gauge cluster from '84 TA with H.O. motor. 8000 RPM tach, 80 psi oil gauge. However the speedometer and temp/fuel gauge has white needles vs. orange. Also odometer has a 6 digit readout with 10ths vs the 5 digit readout after '82. That doesn't seem right.
VERY RARE 1984 TRANS AM GAUGE CLUSTER FOR HO MOTOR ONLY
Old Nov 20, 2005 | 10:42 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
It is either:
1982 gage cluster that someone swapped in L69 5.0L HO tachometer and volt/oil gage into.
or
1983 L69 5.0L HO gage cluster that someone swapped in 1982 speedometer and gas/temp gage into.
In either case, they were too stupid to swap needles so everything matched!
Whatever it is, its definately not an '84 cluster because of the obvious green-blue backlit.
Old Nov 29, 2005 | 12:18 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Wasn't the 80psi oil gauge in the V6 cars?
Old Nov 29, 2005 | 01:11 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Winning bid $51
Bubbajones_ya
Jul 6, 2024 08:32 PM
Dyno Don
Jan 24, 2016 08:24 AM
corey8084
Sep 17, 2015 02:56 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
