rust disolver , what the f***
Old Sep 28, 2000 | 03:09 PM
motley400RS's Avatar
What is the best way to get rid of rust on our 82-92 f-bodies ? I was under my car yesterday and found some just under the driverside next to the pinchweld seem . I was curious if anybody has tried that "rust disolver jelly" , if so , is that worth it? I would like to stay away from those body shops , they charge you up the ****ing *** just to do practically nothing.....F******BASTARDS! Someone HHEELLLLLPPPP????
Old Oct 2, 2000 | 06:36 PM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
If you're talking about Naval jelly, yeah it works but it depends on how much rust is there. I have used this stuff MANY times on my car and I am still using right now (fixing up interior and undercarriage). Your best bet is to use and wire-wheel or rust-remover-wheel for your drill to get the bulk of it off. Then brush some of this jelly on and let it do its thing. sponge it off with a damp rag and paint it when its dry. On thick flaky rust that is deep into the metal, it wont help much. For that, you need to cut it out and weld in a new piece. If you dont have a welder (I don't) use rivets and JB-weld. Hope this helps,
John
84 Firebird with Trans am ground effects- 350 4bbl GM crate motor (LM1), T-Tops, automatic, K&N filter, 180* thermostat, ram-air hood scoop, flowmaster muffler, Accel cap & rotor, MSD Super Conductor Wires. Coming soon: new interior (grey), rear end work, subframe connectors, polyurethane bushings
Old Oct 3, 2000 | 07:34 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've heard a lot of good things about POR-15. Instead of disolving the rust, it chemically changes it into something else, plus it leaves a hard painted-type finish that can be painted over.
Hell, if I used rust disolver on my 86, I'd wind up with nothing but a steering wheel and an engine block.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 3, 2000 | 06:53 PM
Yeah I've heard a lot about POR-15 too. I use something similar called Coroless. This is what I paint the affected area with after the other treatments to make sure it doesn't come back. It is available from Eastwood: http://www.eastwoodcompany.com
I honestly don't know how long it lasts but it seems high quality and haven't had any problems with it.
John
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
