what type of motor do i have
Subscribe
Dec 24, 2000 | 05:41 PM
whats up fellow enthusiasts,
I have a problem i bought a 305 tuned port injection motor from a junkyard and the man said the firebird was a 90' so i figured it was speed density so i bought it including wire harness and computer it was also a five speed. Now the back of the computer number says it an 86 to 89 i didnt see an mass air floww sensor in the harness i checked the fuel rail and all it says is rochester products can anyone help me out to figure out exactly what type of motor is it. I almost forgot it a roller cam so im figuring it must be an 87 to 89 thanks
Paxton_Z
Reply 0
Dec 25, 2000 | 01:10 AM
Does your engine have a MAP sensor.. If so, it's speed density 90-92. I've included a picture showing where the MAP sensor is below... It's circled in green .. If you don't have that sensor, then it'll be an earlier engine.. No real way to tell without the casting numbers...
1990 GTA L98/4L60
Reply 0
Dec 25, 2000 | 01:28 PM
post the # off the front of the block, just below the head on the right side of the block, with these #'s I can tell you what it's from. Chris
Reply 0
Dec 27, 2000 | 01:09 PM
Whats up,
I wish i could post the numbers off the block but i cant due to the original block had a crack when i was rebuilding the motor so i had a new one installed and being the idiot that i am i didnt get a look at the casting number and they junked the block. I ve read in some articles that have information to look at castin # on intake manifold and it says the intake manifold is from a 86 corvette but how is that possible if i have a roller cam which was not included in 86 plus i know its a 305 thanks
Reply 0
Dec 27, 2000 | 06:01 PM
That just means the intake manifold was cast in 1986. It could be for an 86 car or for an 87 car. We need some numbers off the block to know for sure.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Reply 0
Subscribe
