GTA owners help me!!!!
I know as well as most of you do that there are some 88, 89, and 90 GTA's that were made with the factory option of L98 and CC1. I know alot of you frequent this board.
I have an on going "fued" with a fellow member on my message board who say they don't exist! I need to prove him wrong. I even said that I'd prove that there were atleast 1 91 GTA with these options as well. The owner of this car is "BlackSunshine" and he is a member here......
What I need is either a photo of your RPO code sheet or just your VIN number of a GTA with these options from each of these years to prove to him what the facts are, that Pontiac and alot of the info on the net about these cars is wrong!
Thank You.
www.TransAmGTA.com
1992 GTA (226 made), 1 of only 18 "Dk. Jade Met." 92 GTA's, My Window Sticker, LB9, 700R4 4-Speed, T-Tops, Grey Leather, every available option except J65 and U1A.
Current Mods/Upgrades: 80 Series Dual Outlet Flowmaster, TPIS Air Foil, K&N Air Filter, and Mobil 1.
Future Mods/Upgrades: None but a complete restoration.
Best Track Time: 14.6sec@96.6mph
"If it ain't broke, fix it til it is!"
Webmaster www.TransAmGTA.com
My 3rdGen Firebird Message Board!
[This message has been edited by 92GTA (edited January 04, 2001).]
Thank You.
www.TransAmGTA.com
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Just out of curiousity what is th CC1 option? I can look at my information at home if you can tell me what that is.
James
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
James
The guy is a stupid a$$. I've driven several 87-90 GTAs with T-tops. There were definately quite a few made.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
Car: Death Mobile
Engine: 666 c.i.
I think Leviathan (who you to post on the NTB) had a 90 GTA L98. I remember when he was got his car that he chose the 90 GTA L98 because it was the only year with an SD L98 and T-tops. I don't believe that 91-92 L98 GTAs had T-tops. Or if they exist, those are the rare ones.
I know that when I asked about an SD L98 GTA in the spring of 1991 I was told that they were not available at that time. That's why I ended up with the coupe. The T-tops at that time were only available with the 305s...but that was in the spring of 1991.
Car: Death Mobile
Engine: 666 c.i.
GM went to Speed Density start in 1990 for the TPI L98 350 and LB9 305. Prior to that, they were MAF (Mass Air Flow).
The Speed Density system uses a MAP sensor and calculates the amount of air flow based on the pre-determined tables and calculations based on MAP and other sensors.
The MAF system reads the MAF sensor and then computes the flow based on the incoming readings. There are still tables that can be tweaked in the eprom on MAF system.
On that note, I will say no more. There has already been too many SD vs MAF squabbles. If you care to read up on the differences, scope out the TPI and PROM boards. Its been bashed around enough and probably has more information that you really care to know about.
ok.......heres what we found out about the GTA's(me and my friend have one)....t-tops were only offered with the 5.0 305, since a 5.7 350 would warp the roof way too fast. also, a GTA came standard with a 5.7, you had to request a 5.0, usually because you wanted a manual, since it wasnt available with the 5.7 because it put out too much torque.
"When something breaks, it gives me an excuse to replace it with a performace part!"
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
K+N's
JET chip
kenwood head unit, xplod amp, poineer 3 ways
weird rattling noises
dying 350
crappy paint
700R4 on its last leg
hood that won't open
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
K+N's
JET chip
dying 350
crappy paint
thanks Glen and yes 92GTA i am confusing Super Duty and speed density what can i say i am a pontiac man and when i see SD i think super duty.
ok dude12387 for 91 and 92 you are right about them not supposed to come with a 350 and t tops but there were some that got built that way i have no idea how but a couple of guys on this board have them but in 88 89 and 90 you could get the 5.7 and t tops and yes it did warp and crack the roof which is something you have to look for when considering the purchase of a t top car. TINFY
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Which is odd, because in 92 GM actually made some minor structural changes that resulted in a much stronger chassis, yet still didn't offer the t-tops (or at least not many). Betcha didn't know that the 92 chassis was different, did you?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
who has a 350 with t-tops that came like that from the factory?????
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
K+N's
JET chip
dying 350
crappy paint
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
K+N's
JET chip
dying 350
crappy paint
dude lots of people, dont believe me go to the members cars or whatever its called on the home page and look for yourself and please include a year when you are asking a question like the year matters. also go here and read up its a good informative and enjoyable site www.gtasourcepage.com
Transmission: Pro-built 700R4
Sorry, Its been a while since I was able to check this board. Yep, I'm the one with the '91 GTA with a 350 AND T-Tops! I've read every piece of literature that you have and I know why you think they don't exist. But they do. I have one. I can't take a picture of the RPO sheet right now. I am out at sea right now. I will be returning in about a month. 92GTA, you can tell that guy to kiss my a**. He thinks they don't exist, I know they exist. I own one.
'91 GTA with TPI 350 & T-Tops. Just a few mods, if you want to find out just line up next to me at a stoplight!
Car: Death Mobile
Engine: 666 c.i.
Ok Blacksunshine, WHO do you know in GM?
I tried my damndest in the spring of 1991 to get an L98 with a T-top (even custom order), but I was refused. I even have family working for GM.
Do you know the exact build date of your car? I am wondering if there was a certain time when it was available.
Must be nice to have something rare. Let me know if you ever plan to sell it.
Sell it? Not likely. I bought it used almost two years ago. So I don't know how it was ordered. But I know what I got.
Car: 91 firebird now
Transmission: 5 speed
Yea they made a few 92's with 350's and t tops, some of the formulas had them and a few GTA's and one of the firehawks from that year had them, but I am not sure about the Trans am's. Im trying to find a 92 Trans am with t tops and a 350. ( If you find a 92 with a 350 and t tops you best buy it they are very rare) I want one
Originally posted by 92GTA
Correction: The T-Top Firehawk was a factory 305/5-spd car, NOT a factory 350 car.
I have an 89 GTA 350 w/ T-tops...several made this year. Just get the guy to check out the GTA sourcepage.
I don't have a scanner available to post a picture of my SPI label, nor do I have a digital camera...sorry.
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
I don't think anyone can be that "clueless" particularly when they're on a message board dedicated to '87-'92 Firebird GTAs. I think he may be just pullin' your leg to get a rise out of you for some reason.
In fact, I believe RPO (CC1) and the standard B2L/L98 engine in the GTA was the most popular "option combination" available on all '87-'90 GTAs.
The GTA was Pontiac's "flagship" F-body car and they marketed it as such by including many individual options as standard equipment on the GTA.
T-tops were so popular that Pontiac decided to combine them with leather interior as RPO (R6A) for a package savings to the buyer.
I also remember the local Pontiac dealer telling me during the '91MY that the (L98/CC1) option combo was no longer available on any Firebird except on Formulas with black RPO (PW7) wheels.
The few '91 GTA's with the L98/T-top combo that I often hear about on here are a mystery to me. We never seem to actually see one of these elusive GTAs, but we always seem to hear a lot about 'em when this topic comes up every once in awhile. LOL!
-Mike
-Mike
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Straight from the GTA scource page. These folks know what they're talkin about. This should end the debate.
Question #8 - "Could you get a 350 TPI GTA with T-tops?"
Yes, and No. Initially for 1987, only 5.0L GTAs could have T-tops installed; they were not, according to the order sheets, available in any Firebird model with a 5.7L engine. This must have changed at some point during the year, as I have seen 1987 GTAs with both options.
According to Pontiac order sheets and production records, all GTAs were subsequently available with both the 350 TPI engine and the T-top option from 1988 through the 1990 model year. The combination was not marketed aggressively due to structural concerns, but it was available.
Starting in 1991, all 350 TPI GTAs were available as hardtops only. There are a few 1991 5.7L GTAs with the hatch roofs, but it is generally considered to have been unavailable.
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
OMG!!!!
Somebody's quoting me here now.... SCARY!!!!
Mikos 89 is correct on all his counts. The research I've been able to do on the 1987 models confirms that the two options (CC1 & B2L) came together later in the model year, so not all '87 GTAs would have been able to have the two items on the same car. But for '88 to '90, it seems to be pretty common. Pontiac must have agreed.... hence the R6A Value Option package.
All the real tech info I have to go on is the car order sheets for each year, but those were also subject to revision without notice.... i.e. the 1987 deal above.
My order sheets say no 350 T-top GTAs after 1990, and I have never seen one in person.... but I have seen pictures of GTAs and their SPID labels for 1991 that show the T-tops on 350 cars.
I have never seen or heard anyone claim that they have a 350 T-top 1992 GTA, though.... only the PW7-equipped Formula 350 models.
Somebody's quoting me here now.... SCARY!!!!Mikos 89 is correct on all his counts. The research I've been able to do on the 1987 models confirms that the two options (CC1 & B2L) came together later in the model year, so not all '87 GTAs would have been able to have the two items on the same car. But for '88 to '90, it seems to be pretty common. Pontiac must have agreed.... hence the R6A Value Option package.
Really? I thought they just added some goop to lesson the creaks and moans. WHat type of chassis changes were made?
also..
So, no '92 T/As or GTAs were made with T-top and L98? Only a few '92 Formulas, '91 T/As and no Z28s for '91 or '92?
Hotrodboba400
Dec 10, 2019 07:07 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
