RPO---R6P??
Old Mar 3, 2001 | 11:44 AM
92TRANSAMWS6's Avatar
RPO---R6P??
I was told that this option is basically the same one as G92 but with a couple differences. If that's true than I have finally figured my TA totally out So does anyone here know for sure. Thanks in advance cause I really wanna figure my car out
EDIT---and no I'm not trying to find out how rare it is or anything
92 Trans Am WS6
[This message has been edited by 92TRANSAMWS6 (edited March 03, 2001).]
Old Mar 3, 2001 | 09:46 PM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
First used in 1991, the R6P Performance Enhancement Group option consisted of the KC4 oil cooler, the N10 dual converter exhaust, and the performance axle ratio..... whereas the G92 Performance Axle Ratio package included equipment specified for sanctioned, off-road competition: the aforementioned performance axle ratio, plus an aluminum prop shaft, specific fuel tank with high wall reservoirs, specific fuel sender, wide-strainer fuel pump, and specific 12" vented front disc brakes. This option package was available on all Formula and Trans Am models, but not the GTA.
Available on the 5.0L V8s and standard on the 5.7L, the R6P package was required on T/A models when the G92 option was ordered.
Complete uses were as follows:
** Required on 5.0L TPI/5-speed on Formula & GTA, optional on Trans Am 5.0L/5-speed.
** Required on 5.7L TPI on Formula, Trans Am, and GTA.
Hope this helps more than confuses further.....
Frankie Rider, 2
The GTA Source Page
1988 GTA Red 5.7L Hatchback
1988 GTA Black 5.7L Notchback
1988 GTA Gunmetal Metallic 5.0L Hatchback
1981 Trans Am WS6 5.0L..... slated to be replaced by Chevy SB400
1980 Turbo 4.9L Trans Am WS6
Old Mar 3, 2001 | 11:26 PM
Just the answer I was hoping to get frankie My car as that option and explains why it has a 3.42 rear but isn't a G92 car.
I suppose thats why I have the 140mph speedo and 5500rpm redline also.
Thank you
92 Trans Am WS6
Old Mar 4, 2001 | 08:18 AM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Glad to help, 92WS6.....
Frankie Rider, 2
The GTA Source Page
