Twisted seat-backs.
Old Jun 18, 2001 | 11:35 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Twisted seat-backs.
I tried this in Body and Interior, but nobody seems to want to answer.
My seat backs are both closer to the dash on the door side and farther away towards the center console. I lean because my back is twisted to the right. Opposite on the passenger side. My butt sits flat, but not the rest of me.
Birds eye view. \ /
They're not that bad but you get the idea. Is there a way to adjust them? Or mod
them so they'll be straight? Is this just normal wear on the seat? Wasup wit dat?
Thanks in advance
AJ
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Old Jun 19, 2001 | 12:16 AM
Jza's Avatar
Jza
You could probably disassemble it and bend the metal frame back...?
Old Jun 19, 2001 | 11:48 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
It could be something in the backs is bent, or even the tracks could be out of alignment. I don't know how you can fix it except to look everything over and see what seems off.
Honestly though, for some reason all 3rd gens seem to have a little built in lean to the center to them, so i'm not sure you can really 'fix' it.
...ed
Old Jun 19, 2001 | 06:31 PM
AJ_92RS's Avatar
Thanks guys. You told me what I didn't really want to hear , but that was my suspicion too. I have looked at the door side of each seat and seen that there's a metal nipple that rests against a plate. Do you think if I notch that metal plate so that the nipple will rest back a little farther on that side, that it'll work? It's just an idea I came up with and wanted to see if there was a better fix. I guess I'll try it and then let you know the results. I guess 240lbs on it don't help either.
Thanks again
AJ
Old Jun 19, 2001 | 08:22 PM
Guest
Guest
Posts: n/a
There is only a stop on one side of the seat, so modifying that wont help the twist. Its either the seatback thats twisted (very likely) or the tracks are tweaked (also likely). Its easy enough to tell if its the tracks, just look at the bottom and see if its square to the car or looks sideways too. If its the seatback, you will have to do what I did and scrounge the junkyard for a replacement thats not bent up. Bending it back wont work, the frame is weak and wont hold once its been tweaked.
Old Jun 19, 2001 | 09:07 PM
AJ_92RS's Avatar
Hey guys,
"Don't Go Breakin' My Heart" HEHE
I guess I'm SOL then huh? Time to get 4th gen seats!!!!! Just saw pics and I love it.
Thanks again,
AJ
Hotrodboba400
Dec 10, 2019 07:07 PM
aaron7
Sep 30, 2015 09:15 AM
gta90
Sep 15, 2015 04:00 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Thornburg
Aug 27, 2015 11:34 PM
