1987 IROC/ G92, GM3, G80 5-SPeed........ Help..
Hey gang..
This is my 1st Post here...:-)
Recently purchased a 1987 IROC 5-Speed Coupe. Some of the RPO codes are: FE2, GM3, G80, G92, LB9. The car also has the Auto dimming rearview mirror, overhead console and power drivers seat.
How common are these options on a 1987 Iroc??
Thanks for the help..
Sean
Sean
Car: 1987 Z28 Convertible
Transmission: 5-speed
FE2 - IROC-Z Sport Suspension
GM3 - 3.45 Rear Axle Ratio
G80 - Limited-slip Differential
G92 - Performance Axle Ratio
LB9 - 305 TPI
Basically, you own an IROC-Z with the performance axle ratio (G92). In 1987, the 5-speed and G92 received the 9-bolt Borg Warner rear axle assembly with 3.45 gears. The G92 is a desirable option in all years. Whether the 9-bolt is desirable is debatable.
The automatic dimming rearview mirror, overhead console and power drivers seat are included in the top-of-the-line option package, RPO 1SC. Unfortunately, GM never kept records of the number of option packages sold.
All in all, you've got a 1987 IROC-Z that came equipped with almost all the options available that year. This fact in itself makes your car more desirable than most for that year.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig) with 50-hp nitrous: 12.043 @ 112.86 mph.
ATI D1SC (10-psig): 12.056 @ 116.62 mph.
All stats are altitude corrected for 3,100 feet using NHRA's Altitude Correction Table.
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
LB9 - 305 TPI
Willie
darwinprice
17
Oct 11, 2015 11:51 PM
