Camaro build sheet decoding.
Old Feb 25, 2006 | 07:09 PM
Skihorse's Avatar
Car: 1985 IROC
Engine: TPI
This topic has been hit a billion times. I have the GU6 (3.42) but I can't read the plate on the axle to see if it's posi or not. The build sheet has KA in box 11. Is there a build sheet decoder?
Old Feb 25, 2006 | 07:45 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The RPO code is G80 for positraction.You can also look on the passenger side axle tube,looking at it from the input side about middle of the tube.The axle code and build date was stamped in the tube.Now it may or may not still be readable fter being in the weather for 20+ years.I hope this helps some.I'm sorry i can't help you with the build sheet.
Old Feb 25, 2006 | 09:04 PM
Skihorse's Avatar
Car: 1985 IROC
Engine: TPI
No g80 option that I see. The axle has oil/grease caked all over that section of the axle. Tried to scrape of to read but difficult w/o jacking up car. I just picked up car a couple weeks ago and the car has only 55k original miles so it is in great shape. Just that axle leak. I will swap out for posi when I have it serviced. Would be nice to figure out what's there before we open it up.
Old Feb 25, 2006 | 10:53 PM
coolram62's Avatar
Engine: LU5 305 CFI
The code maybe still readable.All you have to do is clean it up.Like i said it'll be on the passenger side tube looking at it from the input side.IT'll be letters and numbers.First of which will be the axle code & open/LS differential.Just have to clean the tube real well includung using a fine wire brush.Only drwback to this is if someone has changed anything.best solution is to pull the cover.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Reddeath210
Oct 6, 2015 08:20 AM
bellez77
Sep 5, 2015 08:39 PM
