1985 350TPI Trans AM
I picked up a 1985 Trans AM (Mechum) with a 350 TPI/ 700R4. Is there anywhere I can get specs on the engine (horsepower, torque, etc)? I'll be using the power train for another project so I don't necessarily need the cars specs- just the engine info. Also, does anyone know what is different about a Mechum TA vs. a 'regular' one?
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
85 TA w/ 350's were not a factory option. It was swapped out at one time. I know there was a shortage of crate 305's around that time, some dealers used the 350's on warranty claims, of course big daddy GM would void the drivetrain warranty, the dealers usually stood behind the cars anyway.
Don
Recaro Seats
58,000 miles
5.0 TPI
WS6 (.92g)
3:27 Posi
Hi Flow MAF
K&N
My Car
TransAmGTA.com Ride of the Month
Don
Recaro Seats
58,000 miles
5.0 TPI
WS6 (.92g)
3:27 Posi
Hi Flow MAF
K&N
My Car
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The car isn't stock (if it is actually a 350) so in terms of specs, your guess is as good as anybody's.
In 85, the only V8 available was a 305. 350s didn't show up until 87.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
The fact is, there were a number of engine, transmission, suspension, exterior and interior mods that were performed by the Mechams. This goes for the late '70s thru mid '80s Camaros, Firebirds and the few Corvettes that they modified. You might want to contact them at: http://www.mechamperformance.com/
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
<font face="Verdana, Arial" size="2">Originally posted by vtravis:
I picked up a 1985 Trans AM (Mechum) with a 350 TPI/ 700R4. Is there anywhere I can get specs on the engine (horsepower, torque, etc)? I'll be using the power train for another project so I don't necessarily need the cars specs- just the engine info. Also, does anyone know what is different about a Mechum TA vs. a 'regular' one?</font>
One thing I can tell you is I can confirm what others said about 350 not being an option in 1985, so I think your engine seems to be a swapped out one, nor was any Mecham-modified T/A available in 1985. Those stopped in 1984.
Hope this helps.
1982 Recaro Trans Am LU5/WS6/Y84, 2971.6 original miles - http://ohok.com/82recaro
1985 basic Firebird, LB8/F41/GU6/DE1, '82 T/A wheels, CB, 131k - Get JPG picture here
1989formula5.7l
Aug 15, 2015 11:35 AM
