Key question
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Key question
If I have the code from the knock-out piece on my ignition key, can I use it to get a new door key?
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
No, I don't think so. The two keys have different codes on them. Do you have your car's factory invoice? If so, the two key codes will be listed on it.
If not, go to the dealer and give your VIN #.... they should be able to get the key codes for you from that information. I've had replacement keys made that way before.
Good luck.
Frankie Rider, 2
The GTA Source Page
'88 GTA Red Hatchback - 5.7L/A4
'88 GTA Black Notchback - 5.7L/A4
'88 GTA Gunmetal Hatchback - 5.0L/A4
Good luck.
Frankie Rider, 2
The GTA Source Page
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I had a replacement ignition key made that way before too. Apparently somewhere along the line, the ignition had been replaced. Key no workie.
Now I get a couple spares made. I keep a spare lock key in my wallet, and I keep a spare ignition key hidden in the car.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Engine: 383 Carb
Transmission: 4L60
Yeah, I was afraid of that. My girlfriend just bought an 82 Camaro, and it has the original ignition key, but the door key looks like a copy of a copy of a copy and only works well in the driver's door.
eightsixseven
Dec 16, 2024 01:50 PM
