Rear Hatch Leaks
Car: 1987 Iroc-Z
Engine: 383ci TPI
Rear Hatch Leaks
My rear hatch is leaking water down into the pull down motor. It appears that the water is leaking where the glass meets the rear hatch. I have an exploded view and it appears there are a couple of seals. I didn't know if anyone had replaced these and knew if they are still available and what the part numbers are. Thanks, I did a search and didn't find any info, so I thought I would take a shot.
Car: 1987 Firebird Formula
Engine: 305 LG4
I used clear silicone as a temporary fix. I have not found the right gasket needed for a permanent fix yet but some people have told me that they used the same black sealing material used to install windshields.
Street Lethal
Apr 30, 2019 12:14 PM
