how to?
Old Jun 22, 2006 | 05:35 PM
jeremys82c10's Avatar
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
Axle/Gears: 8.8 w/3.08's with a trac-lock
how to?
don't know if this is the right place, but do y'all have any directions on how to install a hatch pulldown motor
Old Jun 23, 2006 | 03:43 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
no, this should go in body/interior or perhaps FAQ. but it's not that important. if it gets moved it gets moved...
since your avitar lists your camaro as a 1972 C10 pickup truck i have no idea what this is for. so to answer your question i need to ask one of my own. is this a retrofit into a pre86 fbody? if so WHY THE HELL WOULD YOU DO THAT???
if it is for anything 86 or newer instructions can be found on the TDS webpage. Top-Downsolutions.com is a remanufacturer of Power Pulldown units for the thirdgen fbody. they also produce a number of other usefull parts. if you are confused after reading that documentation you can post back here with your specifica questions and we can help...
Old Jun 23, 2006 | 11:06 AM
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
that is an 82 c10 pickup truck, but its not for that, it is for an 88 IROC, and it comes with it if i buy the car, he said the original one doesn't work right, so i'll already have a new pull down motor to install, thanks for the website.
