83 Z/28 Door Panels
Car: 1983 Z/28, 2017 Camaro SS 1LE
Engine: L69
Transmission: 5 Speed
83 Z/28 Door Panels
I have a 1983 HO Z/28. The seats say "Camaro/Camaro/Camaro on them. The door panels are just plain vinyl. I think I have seen door panels that also say Camaro/Camaro/Camaro and are cloth. I have the build sheet for my car. What should my car have and how can I tell what is should have from the build sheet?
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Welcome to TGO.You'll find a lot of good info and help here.
I believe the door panels should match the seats.At least that's the only way I've seen that style interior.If you look on the front center of the radiator support you'll see a trim tag.It will give the exterior color and interior trim color and type (this along with build date and VIN).These codes will be on your build sheet also.Do you have a way of posting the build sheet?It would be easier for someone to help you decode it.
Engine: L69
Looks like the door pads are code MLW and the car has the Z06 Lux Interior group. I have attached the build sheet. Any one know if these should be cloth or vinyl door panels?
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
