Front/Rear Swaybar rate and part number stickers
Old Mar 3, 2007 | 02:07 PM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Anyone got the dimensions and color for the front sway bar factory rate and part number sticker?
My 36mm front sway bar had the following in the sticker I understand and I got someone that can reproduce it for me: Rate code DDJ part number 14094344 and MADE IN CANADA printed on it and its probabrly blue in color (verify please) so any dimensions, spacing between text rows etc would be really helpful.
Rear sway bar I have no information about so any information about dimensions of the sticker, information printed on the sticker (my sway bar is a 24mm one) and color of the sticker would be much appreciated.
Old Mar 3, 2007 | 03:11 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Interesting. I swapped in the 36/24 combo into my 85 IROC, and I've sold, perhaps, a half dozen sets, and I've never seen a sticker of any sort. The above part # is correct. FYI, the rear is 10035033
JamesC
Old Mar 3, 2007 | 03:32 PM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Thanks for the rear sway bar part number JamesC.
Here's some pictures of the front swaybar sticker ..
(thanks to midwestmusclemachines owner for the pictures )
Dont have one of the rear sway bar sticker but should look the same but have no clue about the color of that one ....
Old May 27, 2007 | 08:11 PM
youngdeezt's Avatar
Re: Front/Rear Swaybar rate and part number stickers
JamesC
how much for that rear sway bar 10035033
Old May 27, 2007 | 08:40 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Check for posts by member MidwestMuscle.He has a mint '89 TTA and a '85 IROC.He's posted pictures of factory decals/stickers and thier placement on them.And I'm sure there are others on here.
Old May 29, 2007 | 11:02 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
jlarrson
I have an 82 Z28 which still has the factory sticker for the front sway bar. I was suprised to find it,, still in very good shape. Sorry I don't have a photo of it, and I don't know how one measures distances on a sticker pasted onto a round bar I do not have a sticker on the rear sway bar.
One interesting item I noted was that the sticker is GREEN. On my build sheet, in Control Arm space 13, Front GREEN 0800R, in space 14 Rear XU BLUE. Then STAB BAR space 21, Front FM, space 22 Rear #21. I had thought looking at the build sheet the Green for the control arm was for the stabilize bar. After taking another look at it looks like the control are refered to above is the A Arm on the front. So I don't have a positive color for your bar, and am wondering if it changed from year to year, and suspension to suspension?
Dave
Old May 31, 2007 | 10:34 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Just about everything would have had a decal or a sticker somewhere on them. The Springs, the sway bars, the throttle linkage cables, if there was a difference or an option that involved that part then they would have identified it. The Aluminum Hood in 1982 had a large "A" even though it used the same exact part number stamped in it (go fig)...
contact this guy http://ras001.0catch.com/stickers/stickers.html He might have something you can use, he does other decals...
John
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
