Does anyone know?
Old Mar 17, 2007 | 02:44 PM
lugnutx2's Avatar
Does anyone know?
I came across a firebird in a local salvage yard that is an AC delete, V8, 5 speed and rear drum brake car. Drivers door and console are gone and the vin is so rusted that it's hard to read. Is this a 1LE car or could you get the AC delete credit by itself ? Thanks, Dave
Old Mar 17, 2007 | 03:28 PM
AmorgetRS's Avatar
In the North AC delete is relatively common on any Thirdgen model. It was available by itself. Also, I don't think any 1LEs had drum rear brakes.
Old Mar 17, 2007 | 04:22 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
AmorgetRS is correct..........all 1LE's came with 4 wheel disc.
Old Mar 17, 2007 | 05:12 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
a/c was optional not standard equipment,
tons of these cars did not get a/c, and not jut these cars but trucks and other stuff too,
extremely common
Old Mar 17, 2007 | 06:22 PM
lugnutx2's Avatar
Thanks for all the replys! Like I said , I'm new to the 3rd generation body. With the prices that the ist gen camaros are bringing it made sense to find another body style, so I just bought a 27,000 mile, 3.1,1991 RS camaro with an engine knock. I'm planning on removing the ac system and installing a 383 sbc/turbo 400. I took the heater box from this ac delete firebird, hoping it will fit my camaro. Thanks, again!! Dave
Old Mar 18, 2007 | 03:30 AM
AmorgetRS's Avatar
It will fit your Camaro :-) Welcome to the wonderful world of Thirdgens!
Old Mar 18, 2007 | 03:59 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
removing the AC is verry common modification, just to let you know: you will have to swap out the controlls on the dash with non-AC ones or your fan speeds will not work correctly. this may involve swapping out your heater box under the dash.
at least thats how it worked on my GTA...
