placement of 1985 trans am deco package
Car: 85 trans am
Engine: 305 tpi
i was wondering if anyone knew the measurements for the bird on the sides and on the hood, i want to put the decos on the car as they have been sitting for awhile now and i dont want them going bad. I went to GM and they said they jsut were stuck wherever but if someone could measure off theirs or already has before the info would be greatly appreaciated. thx in advance.
Re: placement of 1985 trans am deco package
Your best bet would be to find as many pics you can find and decide where you like them and then eyeball them as best as you can. As long as they're close, no one is going to argue too much, and if you like the way they look then you'll be happier with the car. The blow off that GM gave you has it's reality. There's human error involved and even in GM promo material the badging tends to move around.
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
The hood decal sheet should have alignment marks on it.
Car: 85 trans am
Engine: 305 tpi
alright thx for the info, although i did not see any alignment marks on the deco sheet.
My sheet had marks to align with front vents and a centerline mark that you align on the center hood ridge.
It should be fairly easy to find the centerline of the decal, you just need the distance from the front hood vents.
I would recommend you clay bar the entire car before applying decals.
Don
Don
drathaar907
Aug 10, 2015 07:44 AM
