unsure where to put this so in posting it here. i found a 89 formula l98 with ?t-tops? anyway its got a newer paint job on it new leather interior black/dark red and 150k on it. guy wants 2k for it anyone think its worth it? i went and looked at it and its nice i took some pics ill post em but i havent driven it yet ill have to call him again and tell him im interested and want a test drive ect. well info and advice is apreciated
oh and the t-tops and l09 puzzles me thought that couldnt be optioned.?
oh and the t-tops and l09 puzzles me thought that couldnt be optioned.?Senior Member
It seems like a good price to me. Double check the VIN to make sure it really is a 350. It's been said here a thousand times before, but I'll say it again. Every seller thinks his 305 is a 350. You want to look at the 8th digit in the VIN. Here's a breakdown for you:
8 = L98 350
F = LB9 305
E = LO3 305
8 = L98 350
F = LB9 305
E = LO3 305
Drew
close
- Join DateJul 1999
- LocationSalina, KS
- iTrader Positive Feedback100
- iTrader Feedback Score(58)
- Liked:1,067 Times in 758 Posts
Nothing special there except shiny paint. L98+ttops is not unusual for 1989.
The leather isn't original or even a factory option with those seats. I'd say treat it like any other 89 Formula 350.
edit: the price seems fair, assuming it runs and drives fine.
yea i know it isnt original interior the guy selling it works at a upolstry shop where the car is sitting at now. stupid me forgot to check the vin when i was there ill go back tomarrow night since ill be out that way anyway. i know its nothing special but im looking to get into another 3rdgen thats stock that i could drive reguarly and this one seams decent and stock
Drew
close
- Join DateJul 1999
These cars are old enough that even the ones that have been well maintained are going to have problems. I wouldn't expect to get into one and drive it trouble free for long periods of time.
drove it today runs smooth needs map sensor though but has new tranny and starter the ypipe needs tightened up he had to remove it to get to starter but other than that it runs and rides smooth and i got on it and no hesitation got on it at about 20 it chirped but it had more but i didnt mash as hard as i could either but he has another buyer and if it falls though im next on list if i want it
Quote:
well the only way it could have a map sensor is if it was converted to speed density or if its a 305 tbi cause tpi cars only had map sensor if they were 90+ or unless you meant to type maf sensor insteadOriginally Posted by Screamin86
yea sorry i fudged up maf
how could it run smoothly and need a MAF sensor?
anyway, if theres no rust on it, sounds like a deal to me
he had it un pluged
did the car ever reach operating temperature?
yes i drove it
Doesn't have the wrap around spoiler??? Wierd, did you check the vin yet?
Quote:
Sounds fishy to me. I've never had to remove the pipes to remove a starter from a third-gen.Originally Posted by Screamin86
drove it today runs smooth needs map sensor though but has new tranny and starter the ypipe needs tightened up he had to remove it to get to starter Supreme Member
are you kidding? the exhaust is right in the way, especially if its a larger custom exhaust
Quote:
Maybe so. (w/ larger custom exhaust). However, no I'm not kidding.Originally Posted by rwdtech
are you kidding? the exhaust is right in the way, especially if its a larger custom exhaust Just changed the starter in my '89 (TPI motor w/stock 2 cat exhaust) Didn't need to remove the pipes. The pipe wasn't even close to being in the way.
Did a '88 friend's TBI 305 Camaro a few years ago. (Stock single cat exhaust) This one was tight, but I was able to remove and replace starter w/no need to remove pipes.
well im asuming the car sold because ive gotten no call but the spoiler was replaced due to cracking
Quote:
Well it entirely depends which starter is on the car. There were a few different starters used over the years. It depended on whether you had an auto or stick, and on the year. In fact the same engine could use different starters depending on the year. IE: A 92 LB9 auto uses a smaller starter than an 87 LB9 auto, but an L98 from either year uses the same starter. The largest one will not clear the y-pipe.Originally Posted by Rayvan
Sounds fishy to me. I've never had to remove the pipes to remove a starter from a third-gen. Supreme Member
i havent been under my car in a while, but dont you have to remove the exhaust to drop the tranny also?
okfoz
close
- Join DateMar 2001
- LocationDoghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car87 Formula T-Top, 87 Formula HT
- Engine5.1L TPI, 5.0L TPI
- Transmission700R4, M5
- Axle/GearsSag 3.73, B&W 3.45
- Liked:197 Times in 142 Posts
Looks pretty decent, I would consider it personally... I sold an 87 Formula 350 (hard top) that was beat up for $2200... You might be able to turn it for 3000 or 2500...
John
John
On Probation
I thought formula had a wrap around spoiler.
89formula350b2l
close
look at my 89 formy
it did have one he replaced it when he got it painted because it was cracking badly
