Emissions Hoses
Old Jan 11, 2008 | 08:33 PM
acre44's Avatar
Car: 1987 Formula
Engine: 305 LG4
Emissions Hoses
I am slowly replacing all the hoses on my 1987 Formula with the 305 H engine. Does anyone have a source for the original hoses for the emissions systems? I also need a source for the cooling hose that has the T in it. All three of the hoses are attached to a plastic T without clamps, they are crimped onto the plastic fitting. I am not sure if I can fab something up, but I would like to get that original hose. I did check the usual places, gmpartsdirect, rockauto, autozone, advance, etc. without luck.
Thanks for any input.
Old Jan 12, 2008 | 07:23 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Emissions Hoses
Go to acdelco's website and locate a store. I just recently purchased all new belts and hoses for 1/2 the price the dealer wanted. Today, I'm getting a new heater core for about $20. All original AC Delco stuff.
Old Jan 12, 2008 | 10:51 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Emissions Hoses
im just curious as to why you're replacing everything and therefore causing yourself so much headache ,andalso prsumably spending so much $ in the process
im sure that these good used parts can be found in a yard
i have thrown away billions of these such parts in the past, lots in real nice shape
we dont need them up here
many of these part we have taken to the shredder complete and still on vehicles even
if you have a pic of which ones you need then lemme see, as i may have one or more of them possibly;
in the attic
in my automotive rubber hoses stash pile(pretty large)
over at the shop, etc
good luck
Old Jan 13, 2008 | 08:36 AM
scottmoyer's Avatar
Re: Emissions Hoses
I don't understand your question...Why not replace 21 year old rubber components? Rubber has a lifespan and even though they may appear good, could easily give way. The headache comes when you're out cruising and you blow a coolant hose or the heater core decides to give way and dumps coolant all over the carpet. Replacing 21 year old stuff with 15-25 year old parts doesn't make any sense at all.
This is from another website:
"Traditionally, hoses have been visually inspected for failure from the outside. But with today's cars, that method isn't always the best since hoses usually fail from the inside where weakened elements can't be seen and their symptoms not always obvious.
Therefore, replacement of the coolant hoses, especially the radiator hoses, every four years is recommended, regardless of physical appearance.
The materials now used in your engine's construction are different than those of years ago. Cast iron has been replaced with aluminum, plastic and brass. Used together with the coolant, which is also conductive, these dissimilar materials can create a sort of battery with the hose conducting electricity through itself. The electrical current can create tiny cracks in the hose tube which eventually weaken and cause the hose to fail. This phenomenon is called electro-chemical degradation or ECD."
Old Jan 13, 2008 | 08:45 AM
acre44's Avatar
Car: 1987 Formula
Engine: 305 LG4
Re: Emissions Hoses
Thanks for the replies guys. I am replacing them because they are 21 years old and very dry rotted at this point and not very flexible. The car is a show car, lucky if it sees 1,000 miles per year, and by looking at some of the cooling hoses and the emissions hoses they are discolored and you can see the bulge starting near the clamp, which means it will be leaking very soon. After I have spent hours of my time detailing under the hood I do not want a leak ruining it on me or worse yet popping on the way to a show. I will try to locate them through a dealer or get something new that works. Thanks for the offer.
Old Jan 13, 2008 | 09:50 AM
scottmoyer's Avatar
Re: Emissions Hoses
Try locating the AC Delco supplier in your area. I bought all new belts and the upper/lower radiator hoses for less than $60. They are all OEM and stamped with the AC Delco part numbers. Yesterday, I bought the heater core and outket hose for $39. So for a little over $100, I got all new belts, hoses, and heater core. That's not much to pay for a show car and the piece of mind that nothing should go wrong.
http://www.acdelco.com/index.jsp
Use the right side, select belts and hoses and you zip and it will tell you what stores are in your area.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
