15' tire size..
Old Jan 14, 2008 | 07:15 PM
Billfromnj's Avatar
Car: 87 camaro
15' tire size..
Hi all...i recently got a 87 camaro...and the tires that are on the 15's are 225/75/15 in the front. And i believe the rears are bigger or maybe same as front. can someone tell me the correct size that should be on um? like the stock size, i have searched a number of times but could nt come up with a right answer....
thanks
Old Jan 14, 2008 | 07:32 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 15' tire size..
you can check on the door jamb , driver's side . should have the factory size there . that is if it has not been removed , i think 215's are stock ( not sure ) just get a good quality tire for dry/wet conditions . tires are your contact with mother earth .
Old Jan 14, 2008 | 08:11 PM
Billfromnj's Avatar
Car: 87 camaro
Re: 15' tire size..
Thanks Uncle Tom, forgot about checking door jam..
Old Jan 14, 2008 | 08:52 PM
PackmuleTA's Avatar
Car: 1986 T/A,91 Firebird
Engine: LG4 305, 3.1 V6
Transmission: TH700-R4 x2
Axle/Gears: 2.73,3.23
Re: 15' tire size..
215/65/R15 stock
Old Jan 14, 2008 | 09:04 PM
Billfromnj's Avatar
Car: 87 camaro
Re: 15' tire size..
Originally Posted by PackmuleTA
215/65/R15 stock
my door jam says 215/55
Old Jan 15, 2008 | 09:09 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
Re: 15' tire size..
Look closer.
They are 215/65/15.
They were also had with 235/60/15 with the TPI 305.
Leon
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
