Found a build sheet, need some help.
Old Jan 23, 2008 | 10:32 PM
z1colt45's Avatar
Car: 1990 Firebird Formula
Engine: 305 TBI
Hey everybody, I found this build sheet in my passenger side seat. I know what two of these codes mean, the N65 is the spare tire and the AR9 is the bucket seats. Can you guys shed some light on the rest of this?
Attached Thumbnails Found a build sheet, need some help.-ccf01242008_00000-small-.jpg
Old Jan 23, 2008 | 10:34 PM
z1colt45's Avatar
Engine: 305 TBI
Here's a higher res picture in case you cant read that one.
Attached Thumbnails Found a build sheet, need some help.-ccf01242008_00000-large-.jpg
Old Jan 24, 2008 | 03:17 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: Found a build sheet, need some help.
Great find, although technically it's not the build sheet.
See . . . https://www.thirdgen.org/forums/hist...light=assembly
They look like this . . .
But we'd be happy to help you decode it. Hang on for more replys.
Old Jan 27, 2008 | 03:03 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Lots of info. these are the codes that are found on the parts specifically so the assembly line knows what to put in your car.
For example, in the lower right is the rear suspension. NNL - is the code for the springs. In the middle is XH which is the code for the steering box. And so on.
If you search up some of the codes you will find references. The XH steering box is the fast ration 16" tire version.
I have listings of all the GM springs, so I know for certainly about the NNL. I suspect there are other listings for the other codes.
I have some info specific from the Player's race series, but not complete listings.
Mark.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Clean87TA
Sep 4, 2015 11:23 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
