Newbie Question
Old Mar 10, 2008 | 11:52 AM
lcbailey's Avatar
Newbie Question
I just bought my first third gen after a dreaming of one forever. This one does not have any keys. What is the best way to replaec the door and T-Top keys? I am planning to replace the ignition cylinder to take care of that one. Thanks guys.
Lawson
Old Mar 10, 2008 | 01:22 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Re: Newbie Question
You have to take your fdr apart and take the lock cylinders out and replace them.... idk about the T-tops
Old Mar 10, 2008 | 06:16 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Re: Newbie Question
You can take the door panels off, reach in the doors and remove the lock cylinders, same with trunk. Not sure about ttops, but if you can get them off then you should be able to get the lock cylinders out, then take them all to a locksmith and have them rekeyed and have new keys cut.
Old Mar 10, 2008 | 07:10 PM
maro_of_the_92's Avatar
Re: Newbie Question
im sure its the same with the t-tops
Old Mar 10, 2008 | 07:31 PM
92maroguy's Avatar
Car: 92 camaro RS
Engine: 305 5.0L
Re: Newbie Question
Or try to find a junk car with good locks and the key so they are all from the same place but like the other guy said you have to be able to take the tops off (I just had to do the same with mine)
Old Mar 10, 2008 | 07:45 PM
JT's Avatar
JT
Community Administrator
Re: Newbie Question
It depends on the year, but you could just take the VIN to your dealership. Have the dealership lookup the key code for your VIN and cut you the proper keys.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
R3500
Aug 24, 2015 09:05 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
