some speedometer questions
Old May 14, 2008 | 12:23 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
i have an 85 t/a and the speedo bounces a lil bit and makes a noise its been sitting for 2 years is there any lubrication procedures?
also can i replace the speedo with a 1986 + gear driven cluster the ones that show a sporty 140 insted of plain 85?
if so what do i need to do?
Old May 14, 2008 | 05:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: some speedometer questions
Originally Posted by FireBirdKnight
i have an 85 t/a and the speedo bounces a lil bit and makes a noise its been sitting for 2 years is there any lubrication procedures? also can i replace the speedo with a 1986 + gear driven cluster the ones that show a sporty 140 insted of plain 85? if so what do i need to do?
I'm not a Pontiac guy, so take the following with a grain of salt. IIRC, your 85 is a mechanically driven speedo, 86 up electric, so swapping would be problematic. Here's a lube procedure:
With the cluster removed, pull the cable from its housing. Inspect it for burrs, fraying or breaks. Unscrew the housing from the tranny and shoot Brake Clean or some other cleaner down the housing until the fluid is clear. Brake Clean will dry rapidly. While you're there, you might inspect the drive/driven gear for problems. Button up at the tranny. Clean the cable itself, then put a glob of Napa's Sil-Glyde (mentions speedo lube on the tube) in your palm and run the cable through it as you thread the cable back into the housing. You'll probably have to manipulate the cable a bit to reseat it in the speedo sleeve at the tranny end.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
