1987 LB9 Red IROC just rolled 300,000 orig miles today!
Old Jun 20, 2008 | 11:04 PM
Debritton's Avatar
Car: 1987 IROC
Engine: LB9
Transmission: 700-R4
I had to replace the water pump about 6 months ago and also had a smog pump bearing make racket about 2 months ago that required replacement to pass the smog... either then that the car is still running stong. YES.. both power windows still function and even my rear hatch motor still works good... LOL
Obviously this is my daily driver that makes a trek 70 miles a day to/from work- 5 days a week. The car has a rear main seal leak and the intake manifold gasket needs to be replaced--either then that it idles at 500 rpms on the $$$. The rings appear to be hanging in there...but I suspect I am losing some oil past the valve stem seals as it smokes on startup... but not on full throttle...NOR do any of my plugs get oil fouled. If I took them all off right now they would be all clean with normal carbon buildup... When I bought this car about 12 yrs ago... I never thought it would get this far without engine issues....
Anyone else hit this 300 grand mark?
Old Jun 21, 2008 | 10:51 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: 1987 LB9 Red IROC just rolled 300,000 orig miles today!
Is the tranny original?
Old Jun 22, 2008 | 12:26 AM
Debritton's Avatar
Car: 1987 IROC
Engine: LB9
The only major things I have done to the car over 12 yrs were:
Torque Converter (went bad)
Fuel Injectors (Accel)
MAF Sensor
Fuel Pump
Smog Pump
Alternator
Water Pump
Heater Core
Radiator
WHAT I AM SURPRISED ABOUT:
Power windows still work
Rear Hatch motor still works
Air Condition still works
Even Compression across all 8 cylinders (no fouling)
Distributor still original
Oil has alwasy been Castrol GTX 10-30 every 4,000 miles with Fram PH-30. Spark Plugs changed every 20,000 miles.
Old Jun 22, 2008 | 09:25 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
MAF Sensor
Fuel Pump
Smog Pump
Alternator
Water Pump
Heater Core
Radiator
WHAT I AM SURPRISED about:
don't say your surpised about it cause it will break. congrats on your car making it this long. that is amazing.
Old Jun 23, 2008 | 10:55 AM
coconut88888's Avatar
367,000 on '89 RS with T-5 tranny. Never went in the engine...only accessories like water pump, alternator, etc. GM had this program about getting rebates for over 100,000 miles. I went to the dealer and they said it was only for trucks. I would think it means a lot more for a sports car to hit these mileages....
Oh well...
Old Jun 23, 2008 | 11:23 AM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
thats awesome hopefully mine gets to make it there im only at 87,000 but nothing on my car is original just the body
Old Jun 24, 2008 | 07:26 PM
David M's Avatar
Car: '84 Z28
Engine: L69
Congratulations, thats quite an achievement. Two questions: Is your car a hardtop? And how are your seats holding up?
Old Jun 24, 2008 | 08:59 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Be careful.I was just bragging on my 89 chevy 4x4 how the a/c still worked in it.next day a/c clutch started cutting on and off.Thenext day,no cold air .Now I gotta spend some money on my daily beater.I hate doing that.
Old Jun 24, 2008 | 09:18 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I once bragged my Hatch Motor worked good.. Buddies dad slammed the trunk and broke the mounts.. Cost me over $120 to fix.. But I do have to say Top Down Solutions is the way to go!
Old Jun 29, 2008 | 11:52 PM
Debritton's Avatar
Car: 1987 IROC
Engine: LB9
Car is a T-Tops model. The vinyl front seats were replaced with fabric about 5 yrs ago. I drive with the rear vinyls folded down as if the car is a 2 seater.
Old Jun 30, 2008 | 12:47 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
A massive congratulations from me. This is awesome.
Old Jun 30, 2008 | 08:52 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I only have 232,800 to go!
Congrats. That's pretty cool.
Old Jul 1, 2008 | 03:38 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
They are definetly dependable cars if you treat them good! More so than some of todays cars with all of their technology and advancements that seem to only keep them in the dealer garage.
Old Jul 1, 2008 | 06:16 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
285,700 more miles on mine and I will be bragging too. Not sure it will happen in my lifetime at the rate I'm going!
Old Jul 2, 2008 | 03:51 PM
littlesk8cracke's Avatar
about 230,000 on my 84 z28. original tranny. engine out of a 91 with maybe 100,000 miles
Old Jul 4, 2008 | 12:27 PM
RPM WOT L 98's Avatar
Only 297,358 more miles to go for my GTA to hit the 300K mark! Doubt I'll see that.
That is awesome though, congratulations! I love seeing low mileage ThirdGens but I love just as much seeing high mileage ThirdGens. 300,000+ miles is just awesome!!!
Mark
Vintageracer
Jan 10, 2020 05:33 PM
1nastygta
Oct 28, 2015 08:51 PM
LittleFranks
Aug 20, 2015 03:55 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
