undercarriage and engine bay looks...
Old Jun 26, 2008 | 09:59 PM
camaro_boy123's Avatar
Car: 1986 Camaro z28
Engine: 350 v8
Hey guys,
over the past 2 days i have gutted my engine bay and i have started to sandblast ( if it wasn't for a nasty thurderstorm i think i would of finished in one night. But my question to you is? what have you done with your engine bays and wheel wells and underbody? im thinking of sandblasting the whole thing and paint it all at once.
Now was it from fastory all one color or was it just the engine bay and outside of car?
information and pictures are more the welcome@! people post your resto pics!@
cheers
Dougie
Old Jun 26, 2008 | 11:04 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: undercarriage and engine bay looks...
seems like we take the same stand on engine bays and undercarriages
here is mine so far
https://www.thirdgen.org/forums/cama...art-finsh.html
Old Jun 27, 2008 | 07:30 PM
armac's Avatar
Car: 83 ta
Might depend on the year. I have a 83 that the engine bay was body color and the under side of the car was coated in DP40 green/gray. Here are a few picts from my resto. I am doing.
Old Jun 30, 2008 | 10:17 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
my 87 IROC-Z has body colored engine compartment and grey with overspray undercarriage.
Old Jul 1, 2008 | 02:41 AM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Both My cars have painted engine bays and Underbodies all the same color of the car.(white and yellow) Maybe its because they were both southern cars I don't know.
Old Jul 1, 2008 | 09:56 PM
wicked-irocz's Avatar
my 89 looks quite a bit like scott's, only more overspray.
Old Jul 1, 2008 | 10:06 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
For early thirdgens, 82-84 at least, Van Nuys built cars had body color undercarriages and engine bays (they painted everything even the inside), cars from Norwood had gray undercarriages and interior and body color engine bays. Maybe the water based paint that they used at the Van Nuys plant was cheaper so they could spray the whole car with it, but I’m not sure why the difference.
Old Jul 2, 2008 | 01:41 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
My '89 Van Nuys ride looks very similar to scottmoyer's except my undercarriage has about half the red paint overspray. There's much more grey exposed. She's painted red under the hood pretty much the same way.
Old Jul 2, 2008 | 06:52 AM
scottmoyer's Avatar
My car is also a Van Nuys car and the overspray on the driver's side is heavier than the passenger side.
Old Jul 3, 2008 | 09:16 AM
Engine: 350 v8
my god, your cars are so clean under there. Being in canada, the guy before me undercoated it like 4 times and the grease is THICK! its going to be so hard to remove it all. Not to mention how many larger than my fist rot holes i have had to weld patches into. The battery tray was rotted, the drivers and passenger floor was rotted. ive basically had to replace everything on this car, i just need the undercoating off so i can paint the whole undercarriage as well
Old Jul 3, 2008 | 10:15 AM
LeonardS's Avatar
Some of the difference in overspray could be caused by the number of times the car was painted. If a paint job was unacceptable the entire car might be run back through the paint booth a second time or third time. There was also alot of touchup/repair work done offline if a car was scratched during the assembly process. This could account for the extra overspray.
Leonard
Old Jul 3, 2008 | 11:17 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Wow, Scott your engine compartment looks great . Even your reservoirs are like new, mine are all yellowed looking. What do you use on your hoses to make them shine like that? I was told long ago that the best cleaner to use on an engine is Simple Green, do any of you agree?
Old Jul 3, 2008 | 11:35 AM
Axle/Gears: 3.08
Simple Green is really good and used by many. The great thing about it is that it's effective without being a really harsh damaging corrosive liquid (easier on exposed hoses and wires if you overspray). Still be sure to rinse and remove any cleaner that you use and protect the paint. The great finished look on the plastic and rubber is usually not achieved with a cleaner but with detailer/protectant.
Old Jul 3, 2008 | 02:51 PM
scottmoyer's Avatar
I have used Simple Green to detail the engine but only on areas that need it. All it is is a good cleaner. The hoses, rubber and black components have all been shined up with detail spray and vinyl/rubber protectant. When these engine photos were taken, I used Meguiar's detail wipes to detail everything under the hood. They have now replaced that formula with something else and it doesn't leave the same look. Lately, I've been using the Eagle One Nano protectant.
Old Jul 3, 2008 | 02:58 PM
scottmoyer's Avatar
I just went to Meguiars.com and see they still have the old protectant. The new stuff I'm using is the quick interior detailer wipes. The old stuff was the Gold Class Protectant wipes. I need to find me some more of those!
Old Jul 7, 2008 | 07:19 AM
Engine: 350 v8
well well well,
i took all your ideas and combined it into one process. To get off the thick undercoating you need to use a gasket scrapper. Once you have the big stuff off you are best to use gasoline to remove the grease underneath. After that, if you use a wax and grease remover, it will take off the remainder of the oil. So far gas has worked the best for getting the bulk of the oil products off!
just thought i would keep everyone in the loop incase someone else needs to do this later on down the road!
Cheers
Old Jul 8, 2008 | 12:24 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
this is mine the undercarriage looks the same as the body color no undercaoting or anything, i recently bought another 92 (purple) with no motor or trans it looks the same as this one.
Old Jul 9, 2008 | 10:22 AM
RPM WOT L 98's Avatar
My 91 GTA is mostly primer underneath with overspray litreally just on the sides. I should have some pics soon. It was also built in March 1990 so during the strike year, who knows what that might have affected. Scott, that car looks great for 14K miles. It is as clean as my 2642 mile car!
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
