whats the difference
Old Jul 17, 2008 | 01:06 AM
Arctic Cat ZRT's Avatar
Car: 1987 camaro LT
Engine: 350, L98 Heads, HSR
Transmission: TH350
Axle/Gears: 12 Bolt 33 spline 3.55 posi
whats the difference between tuned port injection and regular fuel injection???
Old Jul 17, 2008 | 09:53 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: whats the difference
Fuel injection covers any system where fuel is delivered through an injector, as opposed to a carburetor. Tuned Port Injection is GM's name for a particular Multi-Port Fuel Injection system that uses tuned-length runners.
Old Jul 17, 2008 | 10:34 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Regular injection is quite open to interpretation. For most IrocZ owners, TPI would be the regular injection. But here's some specific injection methods and how they operate . . .
TPI Tuned Port Injection
- First appeared in '85.
- "Tuned" refers to the eight long tube runner design of the intake.
- Known for providing good torque but running about of breath at RPM's over 4500.
- Uses a 8 injectors (a single injector for each cylinder).
TBI Throttle Body Injection
- Also introduced in the mid 80's.
- A relatively reliable and simple design.
- Uses only two injectors positioned over the intake's throttle body (similar location as a carburetor. This is a less accurate air/fuel mixture than the TPI's multiple injector system.
- Looks very similar to a carburated system and can use many of the same parts (intake manifold, air cleaner, etc). This can reduce it's cost compared to the a TPI system. Some call it a smart carburetor.
Those are the two most popular FI systems for the 3rd gen V-8's. There's also a CFI (Cross Fire Fuel Injection) which used twin TBI's ('82-'83).
Old Jul 17, 2008 | 02:36 PM
Car: 1987 camaro LT
Transmission: TH350
cool thankx for the info
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
