Window motor/track lube
Old Apr 20, 2009 | 06:18 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
ok, my drivers window is slower than granny going to country buffet after church on sunday, i know that 9 times out of 10 your track just needs cleaning and lubed to make it travel at a normal speed, this was done with my pass window when the glass was replaced (by a shop) and its quick as can be now.....sooooo to get to my question how do i go about doing this, pref an easy way that dont require drilling out the rivits and all as if i were to replace the motor, if i got to do that to clean and lube than i guess i will put a new motor in when i do it, but i dont see a need to when my factory motor on the pass side went from slow to fast with just a cleaning and lube job
Old Apr 20, 2009 | 06:58 PM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
Re: Window motor/track lube
My windows have been slow from the get-go (compared to current models). I found out, after the fact, that a mechanic had sprayed WD-40 down the window slit of my ride to improve the operation. It did - sped her up to as quick as a granny having to pee after church on sunday.
Old Apr 21, 2009 | 09:07 PM
89RS_82Z's Avatar
well took the door panel off and lubed the heck out of it, i got GM white lithium and GM multi lube (great having friends a GM dealerships that have stuff like that wind up in their car on the way home).....anyway, i highly recomend this to anyone, its as fast as its going to be, id say just as fast as it was new
Old Apr 22, 2009 | 01:26 PM
1Aauto's Avatar
Former Sponsor
This was my advice about a million times out here.The white grease works.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
