part swap from trans am to camaro
Old May 19, 2009 | 02:13 PM
gregy133's Avatar
i have a 85 trans am and want to know if parts from a 86 camaro would fit the trans am
Old May 19, 2009 | 02:43 PM
camaro8tysvn's Avatar
Car: 87 camaro
Engine: 355ci
Transmission: richmond 5 speed
Re: part swap from trans am to camaro
most stuff works other than dash and some body panels but a camaro nose would replace a firebird nose
Old May 19, 2009 | 02:53 PM
jeffwilly's Avatar
Car: 88 iroc convert
I'd love to see a picture of that. Does anyone have one??
Old May 19, 2009 | 04:12 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
I dont but I have seen a camaro nose on a firebird & a firebird nose on a camaro not pretty at all
Old May 19, 2009 | 04:43 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
im pretty sure the fenders need to be swapped as well
Old May 19, 2009 | 06:11 PM
Car: 87 camaro
Engine: 355ci
the fenders have to be changed to i saw one on craigslist a while back a camaro with a ta nose i looked back and couldnt find it
Old May 20, 2009 | 10:27 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The problem with swapping fenders from a Firebird to Camaro or Camaro to Firebird is the fender flairs and wheel openings are quite different.
At a glance they look to be the same, but a Camaro wheel opening is about 1" or so longer than the Firebird. Also the Firebird is more round where the Camaro is more elongated in shape.
The fender flairs on a Camaro have a more definate line where it meets the body, but the Firebird is more soft and rounded.
I think it would be easier to take a Firebird nose and put it on a camaro and then fill in the rear quarter flairs to match the front wheel fender flairs...
John
Old May 20, 2009 | 11:00 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
You can do that but you need to swap out the entire front end. Everything ahead of the doors would need to be replaced. However, like okfoz said, the wheel openings are quite a bit different and it's really noticable once on the car. The only body panels that are the same between Camaros and Firebirds are the doors and hatch and even those have different holes for the ground effects and spoiler. As far as the interior goes, all the dash and console parts are different but outside of that everything is more or less interchangable.
Old May 20, 2009 | 12:24 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
to go back to the original post, what parts were you interested in swapping? And welcome to the site! You'll find a wealth of knowledge here about these cars.
Old May 20, 2009 | 01:51 PM
gregy133's Avatar
i need the drivers door , back seat, and maybe a few small parts inside
Old May 20, 2009 | 03:17 PM
okfoz's Avatar
SHould be no problem, those parts are typically all the same... Except the small parts inside some things are either Firebird or Camaro specific, typically trim, the exception is the dash is obviously different between models... Like Thirdgen ranch said tho, you may have to drill new holes in the doors for the ground effects to work... But the door will fit on the car.
Also if you have a one piece rear seat it will fit in any car, but if you have a two piece, it will only fit in a two piece equipped car... The center for the 2 piece seats is a tube that was welded to the transmission/driveshaft tunnel.
Does that make sence?
JOhn
Old May 20, 2009 | 03:40 PM
gregy133's Avatar
ya that makes sense thanks for the help
Old May 20, 2009 | 06:33 PM
Former Sponsor
Car: Too many
Just so you know, the Trans Am ground effect holes are quite a bit higher than the Camaro ones. If you put Camaro ground effects on a Trans Am door the top half of the Trans Am ground effect holes will usually show so you would have to fill those holes. I don't know if you would want to go to that much trouble when you shouldn't have much of a problem finding a Camaro door.
reiderz iroc
Aug 13, 2015 04:57 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
rh76camaro
Exterior Parts for Sale
Aug 6, 2015 08:57 AM
