91/92 Firebird/Formula/Trans Am/GTA front bumper reinforcement correct paint color
Old Jun 9, 2009 | 12:18 AM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
I hit a deer with my 91 GTA in July/08 and I hope to fix it within a year. I am planning on repainting the entire car and I am trying to keep the appearance as close to factory as possible. One question I have is what is the correct color for the front bumper reinforcement. The part is discontinued unfortunately so I will have to use a used one. The part # is: 10118418. The one on my car is primer black in appearance but I am wondering if it would have been a shiny black when it was new, similar to this headlight bracket. Every original GTA I've seen has one in similar appearance but I am not sure if its from exposure to the elements or if they came that way. The headlight parts were originally shiny black but turn to primer black over time if exposed to the elements. Here are pics of the bumper reinforcement:
Here is a pic of a shiny black headlight bracket.
Old Jun 9, 2009 | 07:25 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Re: 91/92 Firebird/Formula/Trans Am/GTA front bumper reinforcement correct paint colo
That piece on my '88 GTA is low-gloss black. And it's never been off the car before.... or at least since mile 61.
Old Jun 9, 2009 | 07:54 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I painted mine SEM Trim Black (it is a semi-gloss Black) It looks original...
Just about everything that was originally Black on a non-black car should be the Semi-Gloss Black, including the Bows on Convertibles, the T-top strip above the door, the Suspension, axle (if painted) The strut towers mounts, The engine etc...
The only thing I do not like about the SEM is it is almost too semi-gloss, it should be slightly more Gloss IMHO. but no one knows the difference...
John
Old Jun 30, 2009 | 08:10 PM
Net-Viper X's Avatar
Car: 91 Bird w/Aero Pkg - 02 T/A Col Ed.
Engine: 5.0L - 5.7L Ram Air
If you have ever bought a new part from GM, the black colored sealer/primer factory coat is the same as what those parts for your bumper are painted with. Its not like black primer, its got a slight shine too it, but not glossy like exterior paint.
Like Okfoz said, the SEM trim paint may be a bit too flat in color, so if you dont like the outcome from using that, try some Krylon BBQ & Stove paint. Thats what I have been using on my latest project, and it looks perfect. Its heavy duty, has a mild shine without being glossy, and can withstand heat up to 1000 degrees. I have been very happy with the results from it, but dont know about long term durability against weather since I just started using it on this latest restoration, but since its meant for BBQ Grills I figure its tough stuff. The code for it is 1618 BBQ Black.
Old Jun 30, 2009 | 10:00 PM
okfoz's Avatar
I would like to add, that if you have access to a large enough oven, I know for a fact that the semi-glss Black that Eastwood's Powdercoat is darned near spot on... And it is very tough to beat the durability once it is applied...
John
Old Jul 4, 2009 | 10:15 PM
Andy 91GTA's Avatar
Thanks for all the help guys. I will likely have some more questions once I get my car out of storage.
Old Jan 20, 2013 | 07:57 AM
knight72's Avatar
Car: 1992 W68 Firebird
Engine: 305 5.0L V8 TBI
I'm also looking for this part... pm me if u have one.
Old Jan 21, 2013 | 11:58 AM
92GTA's Avatar
"GM Trim Black" is the actual name of the color. It's used in many places seen and unseen.
Old Jan 21, 2013 | 12:08 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Its a semi gloss black with a slight brown tint to it.
The stamped metal parts and the cast parts are a different tint along with a different gloss than each other.
Look into the JohnDeere line of spraypaints, veeery close to what GM uses on this part.
Old Jan 23, 2013 | 02:18 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Should be just regular semi-gloss black...if you want to make it factory correct, make sure to only put like half a coat of paint on it. There's little to no paint on mine, at least on the skinny "bar" part of it. Paint is a little thin on the larger parts as well, but noticeably thicker than the "bar" part.
Old Jan 23, 2013 | 02:46 PM
TTOP350's Avatar
That paint gets thin over time being out in the weather or just from driving.
If you see NOS parts or a car stored inside with less than 1,000miles you will see the true thickness and colors/ tints. It surprised me when I saw the differences.
Old Jan 23, 2013 | 08:31 PM
florida_gators's Avatar
Car: 1990 Firebird
The bar on my '90 is the same color as the rest of the car and engine bay (GM 75 - the darker red). But the ones I've pulled from junkyards are all the black everyone else has described. I've owned the car since '97 and am fairly certain the bar was never repainted. Since I'm doing a complete restoration, is the original color at times the car color and at times black -based on where the car was manufactured and/or the production year?
Old Jan 23, 2013 | 08:41 PM
TTOP350's Avatar
Nope, none body color.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
