Rear hatch alignment/adjustment
Old Jul 11, 2009 | 12:55 PM
JC63199's Avatar
Car: '86 Z28
Engine: Locked up 305
Transmission: 700R
Is there an adjustment for the rear hatch on these third gens? My hatch spoiler when closed sits about a quarter of an inch higher than the quarter spoilers and the hatch doesn't latch. Which is okay for now, since it's powered and there's no battery in the car and I don't have the door keys. Just looking for advice when I soon get her ready. Any advice will help, and it is all original car nothing has been replaced.
Old Jul 11, 2009 | 01:10 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: Rear hatch alignment/adjustment
Almost all thirdgens have the same problem.. When you get a battery in there and that motor can move up, it should latch just fine.. It's a common factory problem.. Atleast from what I've read...
Old Jul 11, 2009 | 08:52 PM
bcnvz28's Avatar
Car: 16 Equinox,12 Silverado,91 Z28
Engine: 3.6l, 5.3l, 305 H.O.
Transmission: 6 Spd auto, 6 Spd Auto, 4 spd Auto
If you find you need parts or GOOD info contact Lon @ http://www.top-downsolutions.com/
He is very knowledgeable and helpful. Check "Vendor Reviews" to see his good reputation.
Old Jan 19, 2010 | 12:31 PM
locutus918's Avatar
Car: 89 formula firebird
Engine: formula 305 TPI
Transmission: 5 speed
Axle/Gears: 3.45
im new here dont know much about wokring on cars kudos to google but i have a diffrent adjustment problem its on a 89 formula if it matters but when the motor sucks it down the hatch is following the car about a half inch i need to know how to move the whole hatch forward i was told its on the body brackets with gas rods unhooked but is it the part of the bracket attached to glass or the part of the bracket attached to body
Old Jan 19, 2010 | 09:04 PM
Drew's Avatar
In general, avoid messing with the bolts through the glass... Make the adjustment on the body side if possible, that way you don't risk shattering the hatch.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
