Need some help on T/A
Old Jul 11, 2009 | 10:28 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
recently had an 82-83 Recaro T/A given to me as payment for some work...
here is the cowl panel.
Edit:
Found a better pic!
Could someone please decode this jewel for me?
Old Jul 12, 2009 | 06:59 PM
draco's Avatar
Engine: 5.0l TBI
Re: Need some help on T/A
how about maybe some info so I can decode this myself?
Old Jul 13, 2009 | 02:21 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
I'm no expert at decoding the metal cowl tags, but here is what I see. Hopefully someone with more knowledge about them can confirm or correct me.
18E thru CC1 are your RPO codes that tell what options are on the car. I know CC1 is for T Tops. There is an RPO decoder on this site that can help you decipher the rest.
LU5 is the engine code, I think that is a Crossfire 305. The N09 may be emissions or the trans code. I think the D80 is the rear axle ratio.
The portion on the star line starting with 2FS may be a portion of the VIN number, and I think the N means it was built at Norwood, Ohio.
Again, no expert on decoding those, so hopefully someone else here will chime in that knows better than me. Just pointing out what I see; hope it's right!
Old Jul 13, 2009 | 08:34 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
It is a 1982 Recaro.
It is a Norwood OH car. Built 5th week of April. Crossfire, Black int and exterior, locking gas cap.
Decoded here using Wildjeff's guide.
http://www.82firebird.com/82decoding.aspx
You can find more info here: http://ohok.com/82recaro/index.html
and www.earlythirdgen.com/forums
F-body-fan
Nov 4, 2015 06:13 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
F-body-fan
Sep 23, 2015 06:36 AM
F-body-fan
Sep 19, 2015 09:02 PM
