84 TA HO question
Old Jul 15, 2009 | 10:19 PM
RicksIroc86's Avatar
Car: 84 camaro z28
84 TA HO question
im goin to look at an 84 TA saturday and the guy says its an HO. how can i tell, would there be a letter in the VIN or something?
Old Jul 15, 2009 | 10:36 PM
AmorgetRS's Avatar
Re: 84 TA HO question
Yes, the VIN will have a G in the 8th position instead of an H.
Old Jul 16, 2009 | 07:29 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
In addition to that, you want to look for an electric fan and an 8k RPM tach.
Old Jul 16, 2009 | 08:59 AM
pontiacguy1's Avatar
The '84 HO cars got a lot bigger exhaust manifolds, the electric fan, bigger exhaust system (that was also stainless steel), flat top pistons (to raise comp. to 9.5:1), slightly larger valves in the same heads, the cam from the 1982 cross fire corvette, and that's pretty much it. That accounted for the difference between the regular LG4 305 and the L69 305 HO.
If it has a factory belt-driven fan, then it is a regular 305. The exhaust manifolds on the HO engines look much larger than most others, and they have larger down pipes and a larger pipe going back.
The vin will tell what was there from the factory, though. YOu can also look at the codes sheet under the console lid and look for L69.
Old Jul 16, 2009 | 09:29 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
The Trans Am's with the L69 H.O. engine also had a special air cleaner that used the hood for air intake. The air cleaner looks like a regular carb'd unit with the exception of a hole on the cover where it mates with the hood.
Old Jul 16, 2009 | 10:08 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The LG4 T/As got that too. The service manual misstates it as a L69 only piece.
Old Jul 16, 2009 | 10:18 AM
Car: 84 camaro z28
ok thank you for all the information!
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
