Quick t-top question, need some help
Old Sep 6, 2009 | 03:18 PM
Nizzy08's Avatar
Want a title? Post!
Car: 1992 Camaro RS
Transmission: 700R4 w/shift kit
Axle/Gears: Stock
Did they change the style of the t-tops at anytime during the third gen?
Old Sep 6, 2009 | 08:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Quick t-top question, need some help
Yes, they did. The early years had tops with hooks to hold instead of pins. There were also C&C tops, which were different alltogether, as they were aftermarket tops added by a different company (the C&C tops may be the ones with the hooks, I'm unsure here - these were 1982 - 1983 or 1984 cars). The later years had factory glass tops, until 1990 maybe? when the switched to Lexan plastic tops. The Lexan tops had larger pins than the glass tops, but they were the same shape, and thus swappable with one another. Most Lexan top owners look for glass tops to swap, because the Lexan cracks up from sun heat and looks bad from the inside. My car is a 1992, had Lexan tops, I swapped for glass. Firebird and Camaro tops are swappable between the two. That's my limited knowledge.
Old Sep 9, 2009 | 09:28 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
My t tops fit on both cars; 86 - 92 except the 92 has lexan's
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
