Found heads in new house.
Old Sep 14, 2009 | 03:55 PM
marklthomas's Avatar
I have found a set of heads in the house i just moved into. I cannot find any information on the casting number. 3870126. Seems to be from the 60's. Based on similat numbers I have found. Checked motech no luck. I am currently planning on an l05 build to put in my '89 ls. I just want to know if these heads are worth anything. They do seem to have bigger intake runners than the swirl ports. Any input?
Old Sep 18, 2009 | 07:34 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Found heads in new house.
Do a search on Google for "casting 3870126" I found some information, apparently the heads are from a 1967.. first link.
John
Old Sep 18, 2009 | 08:17 PM
daveb123's Avatar
Car: 82 Z28
Transmission: BW T-10
My "standard catalog of Chevy casting #'s" does not show 3870126, but it does show
3970126 as as 69-72 350 truck and base passenger car. Measure the intake valves- most of them had small 1.72 valves, which are useless- if they have 1.94 valves, they are much more useable. You say you're building a L05, which is a truck TBI 350- is that so? IIRC, these heads have 74CC combustion chambers, which is WAY too big for a 305.
Old Sep 21, 2009 | 08:34 AM
okfoz's Avatar
He stated LO5, which is the 350 version of the LO3... I suspect he is talking about something other than a Camaro because he mentions LS...
John
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
