b4c 700r4 3-4 WOT upshift?
Old Mar 1, 2010 | 05:03 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
I can't remember where but I could swear I heard that the b4cs had a different trans set up that allowed them to shift into 4th at WOT. Am i crazy or is this true?
I tried searching but got no results specific to what I was looking for
EDIT: i found mention of it in the FAQs but it doesn't specify whether it was put in the B4C Camaros or if it was just put in some police cars. I know it is called the b-body fix after doing more research so it makes me think my car didn't come with it
Old Jan 9, 2012 | 01:20 PM
b4c-1le's Avatar
Car: "92 RS Camaro B4C/1LE 25th Anniv.
Engine: L98 w/corvette heads & ZZ4 cam
Transmission: built 700R4 with Hughs converter
Axle/Gears: 3.23 posi w/1LE brakes
Re: b4c 700r4 3-4 WOT upshift?
The B4C's did come with a different calibrated transmission which allowed the car to stay in 4th gear at WOT to reach speeds over 150mph. The "B-body fix" was a GM parts kit that had the necessary springs, a different servo, and other parts to convert a 700r4 to stay in 4th at WOT. The kit became available for B-Body police cars to allow them to reach higher speeds without down shifting. I have the part number kicking around somewhere, and probably have the kit as well as I recall buying it but never installing it.
Pac J
May 17, 2020 10:44 AM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Damon
Sep 26, 2015 04:29 PM
6998poncho
Sep 25, 2015 02:56 PM
