GTA Door on a formula?
Old Oct 11, 2010 | 07:40 PM
stevensalmons1's Avatar
I bought a formula with new paint, they jammed the car and had the door panels off. Well today after cleaning and redoing the insert of my door panel, I went to put it on. The door panel will not fit, the armrest on the door structure is one long solid piece. The door panel has two holes for the armrest structure to pass through. I'm 99.9% sure I have a gta door on my formula. My question is, does anyone know if my door handle bezels and armrest will fit if I change the arm rest structure. The car didn't come with the handle bezel or I would just hold it up and see if the holes line up. I have the hard plastic cupholders not the map pockets, I know the cupholders will not bolt up.
Old Oct 11, 2010 | 07:50 PM
Drew's Avatar
Re: GTA Door on a formula?
The door shells are all the same. The bracket for the GTA style door panels is different then the normal door pulls, but it's easy enough to knock out the rivets and put the normal brackets on the door.
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
