Not sure what I have here
Old Oct 24, 2011 | 09:34 PM
burnsy's Avatar
Hi Guys
I have been doing some reading here and I am a little confused I just bought a 1989 Irocz convert from an 83 year old gentelman who is suffering from the onset of Alzhimers he bought the car from a a friend of his in the US who was a GM dealer he bought it in 1990 and was told it was modified by the dealer and GM for use as a pace car so the RPO sticker is missing as a result of changing this car from an Auto to a ZF6 I pulled the build info from GM and this car has a few wierd options it has the LB9 option but also has dual cat exhaust and 4 wheel disc brakes but no G92 or J65 nor does it have N10 and the wheels and steering wheel pictured below the steering wheel says International Race of Champions on it as well as the bowtie all other options seem to be as listed but the trans and exhaust seem to be factory or at least dealer installed using GM parts the wheels look to be TA wheels and ideas as to how I can verify this info does Chev have anything like PHS does for Ponchos
Here is the build info I pulled from GM
11Q
15P
40U
6ZW
7ZW
829
82C
82I
8NL
90A
9NL
A01
A31
AC3
AG9
AM9
AR9
AU3
B18
B34
B35
B84
C60
CD4
D34
D6E
D88
DG7
E5Z
Old Oct 25, 2011 | 04:11 PM
87 player bird's Avatar
Car: 87 player's trans am a4u (pepsi car
Engine: 305 tpi
Transmission: 5 speed
Axle/Gears: 3:42
Re: Not sure what I have here
A canadian dealer can print out all the option codes with a vin #.
Old Oct 25, 2011 | 04:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
does the car even have a zf6 in it? check and see. That will determine if this is all a load or if its possible legit.
Old Oct 25, 2011 | 05:25 PM
burnsy's Avatar
Here is a list the dealer printed is it ok to post a VIN hope so LOL any help is much appreceated and yes it's a ZF6 I put it on the hoist today and my tranny tech verified it I work at a GM dealer also parts guys checked it and it's a ZF6
20111017_121401.pdf
Old Oct 25, 2011 | 05:45 PM
burnsy's Avatar
I just bought it because I have always wanted a 3rd gen rag top with a stick LOL I only paid 1500.00 for the car and the body and under carrage is in great shape she needs paint an some TLC but it runs great could use a little more ummph but it's only a tpi 305 so I don't know if I have to move up to a 5.7 or if I can massage the 305 up to the 400hp range LOL
Old Oct 25, 2011 | 07:37 PM
Drew's Avatar
Sounds like your typical Iroc/Z28 convertible... Lower output LB9, auto, highway gears. Whatever was modified after the fact, it left the factory as a normal Camaro.
The ZF6 was a popular upgrade before the T56 gained popularity. SLP used to sell most of the parts needed to do the swap. Without supporting documentation, the history of the car is going to be difficult to verify. It could have just as easily been modified by an enthusiast as the story you were given.
There's a reason no one has gotten very far with a 305. Not much chance of 400hp without a power adder.
Old Oct 25, 2011 | 08:21 PM
burnsy's Avatar
Thanks i think a swap to a 5.7 carb might be the answer bought it for fun
