91-92 Firehawk flywheel and clutch questions?
Old Mar 14, 2012 | 11:45 PM
JekyllandHyde's Avatar
Car: 87 Trans Am GTA
I was wondering, the original 25 Firehawks used the ZF 6-speed out of the C4 Corvettes and had a special bellhousing made up to be able to fit them into the F-body. Does anybody know if the Firehawks also used the same dual mass flywheel and clutch combination? Or was their clutch setup also custom?
Old Mar 15, 2012 | 09:07 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 91-92 Firehawk flywheel and clutch questions?
The firehawk has its own bellhousing.
From what I have taken pix of, seen and remember the base hawks used the factory Fbody 1piece seal flywheel clutch disc, pressure plate, throwout bearing, fork and hydraulics.
The aluminum 2 piece seal motor cars used a dif flywheel from a 85? T5 setup?
It also uses its own stamped steel trans Xmember. But a 89 TTA part will work.
Old Mar 19, 2012 | 10:28 PM
t_towner's Avatar
From what I have taken pix of, seen and remember the base hawks used the factory Fbody 1piece seal clutch,disk, pressure plate, throwout bearing, fork and hydraulics.
Sounds right but the input shaft on the ZF tranny is different.
Old Mar 19, 2012 | 10:45 PM
TTOP350's Avatar
I'll have to see if it still uses the late model GM spline disc.
Frozer!!!
Jan 19, 2024 04:55 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Trickskier
Aug 29, 2015 01:12 PM
redmaroz
Aug 16, 2015 11:40 PM
