What would you pay for this car?
Old Aug 8, 2012 | 12:17 AM
rffanat1c's Avatar
Car: 1984 Z28
Engine: 5.0L H.O.
Transmission: Automatic
Axle/Gears: IDK
Just curious what you would pay for this car? 1984 Z28 L69 H.O. 69,000 miles third owner. New paint, new front brakes, rear disc, MOOG tie rods, center link, idler arm, clean interior, T-tops. Comp camp XE262H, new valve stem seals, new valve springs, new lifters, and Flowmaster Muffler. Motor is solid with no oil leaks or other problems. All new sheet metal except doors and right rear quarter panel. Pictures are under my profile in my album. I would like realistic numbers please. Thanks all.
Old Aug 8, 2012 | 09:19 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: What would you pay for this car?
I would realllly look for rust all over... The big red flag to me is the "New Sheet metal"
Old Aug 8, 2012 | 01:54 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
It sounds like rffanat1c is the current owner...that being said, why did you replace all the sheetmetal? If it was because of rust, then I can only imagine how bad the underside of the car is, and that alone is going to put the value of this car at next to nothing.
If the car *is* solid, then I would put its value at no more than $3500 retail. My number would be higher if it had a correct hood; I can only imagine that there are other issues/incorrect parts just based off the fact that it has a base model hood, which makes me assume that other corners were cut when the car was "fixed up".
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 9, 2015 03:00 AM
Poncho92
Aug 7, 2015 08:15 PM
