camaro dash pad
Old Sep 21, 2012 | 11:43 PM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
camaro dash pad
i pulled a dash pad from a camaro either an 83 or 84 and im not as familiar with camaro parts as i am with firebird, is this correct for the early years and at what point did the pad change?
i will be listing this for sale and i want to make sure that i represent it correctly. has a little damage on the driver side
Attached Thumbnails camaro dash pad-dscn33112.jpg   camaro dash pad-dscn33122.jpg
Old Sep 21, 2012 | 11:59 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: camaro dash pad
that is '84-89 style pad,far less crack prone than '82-83 type
Old Sep 22, 2012 | 08:29 AM
82RZ's Avatar
Car: 2000 SS Camaro LS1
Engine: 347 cu in mild mods
Axle/Gears: 3:42 or 4:10 depends on what I'am d
Re: camaro dash pad
Hard to tell from the photos. If possible, please take a clear pic of the front edge which faces the driver.
Old Sep 22, 2012 | 08:43 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: camaro dash pad
84+
Old Sep 22, 2012 | 11:10 AM
yo soy el warg's Avatar
Re: camaro dash pad
That looks like an (84-sometime in 89) if the holes punched in the speaker grills are in the shape of a rectangle. It is hard to be certain because of the picture quality. I say this because my 88 convertible has the same dash pad as the one pictured with the rectangle pattern punched out for speakers and it is an original one.
My 89 convertible has a different one than my 88 and it is also an original one.
My 89 has the same dash pad as my 92 RS which is also an original one. The only difference between the (84-sometime in 89) is in the "holes" punched out for speakers in the (sometime in 89)-(92) dash pads it is in an oval shape and not a rectangle shaped punch out. I'm talking about the holes that go all the way through the dash pad, not the shape of the rectangular grill that is molded on the pad. I also say (sometime in 89) because I have seen early built 89s that have the rectangle shaped holes punched out instead of the oval. They may have also changed manufactures at this time?
I haven't read or heard of anyone noticing this difference before. I'm just pointing it out for those that want to stay all original from (sometime in 89-92).
Old Sep 22, 2012 | 11:11 AM
Re: camaro dash pad
It posted twice.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Street Lethal
Aug 14, 2015 08:25 PM
Vintageracer
Aug 11, 2015 08:13 PM
