Rear end restoration
Old Sep 25, 2012 | 12:57 PM
Time2Fly's Avatar
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
Does anyone know or have opinions on the correct way to restore the original finish on a rear end? I am pretty sure the rear end came from the factory without paint. I had thought about blasting the rear and then shooting it with high temp clear but I am not sure if that would be the correct finish. Any thoughts? What would you or have you done?
Old Sep 25, 2012 | 01:10 PM
BADNBLK's Avatar
COTM Editor
Re: Rear end restoration
Might check this out. Chazman posted this somewhere and I saved it... amazing!
http://www.ridrust.com/restos.asp
Old Sep 26, 2012 | 09:24 PM
Time2Fly's Avatar
Car: 1991 Z28
Engine: 400 ci LS3
Wow, that stuff seems pretty trick - the rear end in the pics looks really good. I have some "Marine Clean" by POR 15 I am going to try on a small area and see what I get. I like the idea of doing it with a chemical (vs blasting) as I think it will have less chance of altering the finish of the metal surface. If that doesn't work I might buy some of that Ridrust.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
